[Z06] New Clutch recommendations, RPS,Mantic,Monster,Mcleod??
Looking for some experienced input for a new clutch selection for my aggressive Zo6 LS7 620rwhp Normally Aspirated setup. Intended usage is street, drag racing with drag radials, 1/2 miles events and road course. Must not chatter on clutch release and allow fast shifting without damage to synchro's. An overly lightweight clutch is not really in the cards as my rotating assembly is very light and tuning issues have been prevalent.
Looking at:
1) RPS street twin carbon
2) Mantic 9000 ceramic
3) Monster L1-s twin or triple
4) RXT.
Thanks everyone!!!!
Looking at:
4) RXT.
Thanks everyone!!!!
My RPS lasted about 14k miles. The engagement range was very short as well. Other than that, it was a fantastic clutch and drove very nice. I will never buy one again given the first two items. I got just over a year out of the clutch (I drive the car a lot) and that did include a bit of track time, but that's still a very short life span.
I just finished installing a Mantic 9000 921202 in the car and can tell you that it drives very nice (no chatter), but I've only driven the car once so far. If the lifespan is decent, I would buy another one in a heartbeat.
I did consider buying a Monster as well and have nothing against them. They look to be a fantastic solution as well.
If you are going to be doing a fair amount of drag racing, then you probably would be better off looking to ceramic disks. Don't think I'd use the LT1-S. You ought to look at the ceramic version.
If you are having some off idle, lower rpm drivability issues with an aggressive camshaft, then a lighter flywheel will only make things worse. I'd look at steel flywheels only, and not the trimmed down/reduced weight versions.
I don't drag race. I do however need to replace the clutch. Really torn between the LT1-S and Mantic 9000 Organic. When it comes to clutches in this car, I won't be squabbling over price too much. Way too much of a PITA to install to be pinching pennies.
I have some reservations about organic pad material for 1/4 mile drag racing. I have a Billet steel ZR1 clutch now and did not hold up to any slipping of the clutch and quickly heated up and caused 2nd gear engagement issues even with a brand new RPM transmission. I am trapping mid to upper 130's.
BTW, I got my Tune figured out, no more "scaled Tune" my tuner used the wrong fuel injector values, he corrected it and runs much better. Still room for improvement but fine for this year.
I agree 100% with you Michael. The amount of work to change these clutches makes me sick! I am leaning toward the mantic 9000 ceramic as of today, but who knows. Tony Mamo is suggesting the RPS street twin Carbon he says is weighs around 40 lbs.
Glad to hear about the tuning. The scaling he did was not right, whoever did it. I was trying to be diplomatic at HPT, but it was totally jacked. Feel free to send me the new cal if you want another set of eyes to look at it. Did you ever figure out scan tool? Get a few logs??
Keep your total assembly to like 50 pounds (factory is like 57 pounds) or more. I agree with the light flywheel comment above it sucks for stop and go traffic. Once you are moving fine but that doesn't help anything under 5 mph.
Eli-Z06 (03-20-2024)
This assumes NA cammed car blower car different story.
Buy the Monster Triple. It drives like stock, makes little to no noise and will hold more than 1000whp. It is a fantastic clutch and it also doesn't require any break-in.
Hard to find the perfect clutch. My mantic has been flawless for last 25k miles now. Can it chatter? Yes. Can it make noise at idle, yes. Does it, no. You quickly learn to drive around it and bumping idle speed up slightly gets rid of any noise at idle. Drives smooth and holds 1000+ all day. Wouldn't touch a rxt. Monster maybe but as md said you will want ceramic disc which may make noise and chatter.
I would speculate on a bad install. I can safely say that I have abused my RPS more than any clutch should be abused. This included 100s of high rpm launches, 10s of thousands of street miles and teaching my teenage daughter to drive a stick.
tdeweese (09-25-2016)
Mantic now makes a heavy flywheel so set up weighs 50 pound instead of 35 pounds. Other than that I like the Mantic.
With all brands, builders tend to get brand loyal once they find something that works for them. And then they get real ornery over brands/manufacturers that give them troubles and do not forgive them..... I know I'm guilty of it on some things. That may be why Tony likes the EPS. That's way some builders like the Comp trunion 'upgrade'....
RPS is a solid unit.
Never read a bad review of the Mantic.
Never read a good review of the RXT.
I had a monster lt1 sc and it was so difficult to drive with, monster customer service is amazing and he replaced it for free with a lt1 s twin clutch and my god it's amazing
I would buy monster alone for there customer service , not many companies out there like that
I'm around 560 whp NA
Drives like stock if not better
I have the standard weight organic Monster LT1-S in my cammed Z. I don't drag race, so I only have 3* 1/8th miles passes on it. I do autocross, so I have consecutive standing launches and it doesn't miss a beat. Also took the abuse from San Francisco's crazy steep hills with no issues
All in all, I've been very pleased with it. I would be temtped to try a Mantic but I have no bad experiences with the LT1 so it would be hard to sway from it.
