[Z06] Blown LS7 - Replacement cost??
Blew my 2008 LS7 motor a week ago. Dealer has quoted 21.9K with tax for a replacement engine. For those that have cracked this nut before me, is this in line with what you paid? They do provide a 3 yr 36k warranty. Car has just over 19,000 miles, stock engine, and has been well maintained with regular service from the dealer. Happened during a DE event of which I do about 3per year for fun . Always careful not to over rev, turning maybe 6k when it happened. Dealer says #1 pistón failed and went through the block. I suspect that this is a dropped valve that caused it, but they seem clueless about this issue. Just came off of aftermarket warranty sold by Chev dealer where i purchased it and I was going to get the heads done soon. Shame for all of us to have to worry about this valve issue and having to resort to aftermarket solutions. GM has somewhat acknowledged the issue but I'm sure it's understated since so many are garage queens and don't get run much. Love the car and hate to part with it, but I'm having a hard time justifying putting 22k into it. Has anyone h. ad any luck with customer service working with you a little with the cost of the motor?
are the heads ok?
Is the crank ok?
How bout the majority of the rods?
Depending on what you can salvage, a new LS7 block from GM is ~2700, then you have more costs depending on what can be salvaged and what is trash.
22k could buy you a bad *** ERL, LME, RHS, etc... motor with some sick heads, etc...
Is the crank ok?
dp201 (06-27-2016)
are the heads ok?
Is the crank ok?
Is the crank ok?
Sorry about your motor. When I had 10,000 miles on my car, I got my heads done because I did not want to drop a valve. Then after a few very enjoyable years I left CORVETTE FORUM because it wasn't fun for me anymore. Same old, same old, blown motor threads and uncivilized discussions about the fix. Now, 7,000 miles after I got my heads done, I am back because it seems to becoming evident that my new heads did not solve the problem. Right back where I left off, thread after thread about LS7's with catastrophic failure. Again, sorry for you loss.
summit and jegs both offer these engines 12500 with free shipping
dp201 (06-28-2016)
if no warranty, sell it for salvage, and if you desire, buy another...IMO your car is too old to justify spending that kind of coin on repairs.
too bad this happened, for sure...
I cant remember the chevy dealearship, but its in PA , I think its a bit more, but intake is there water pump, damper, pullies, plugs wires, etc. I think they gave me a price of 12,995.00. might be lower, i would have to check my composition books. then you need to supply oil cooler, lines, the 2 that go into the tank. thats about 500.00+. Now then, you have a new motor. Thats all stock. Got the info from here. When my motor dropped a valve. Went a different route.
Find someone who is building a big FI build and selling their stock motor. I sold my stock short block for $3500. Friend sold his for $3800. Another friend picked one up for $3500 after dropping a valve. Then, even if you put $1000 into it to refresh it, you are ahead of the game.
If heads are trashed, just pick up a set of used heads, put the $300-1000 into them for new guides/valves/etc. With gaskets/etc you can do it for $7k or so if you find some decent deals. Then you need to replace the oil system, etc etc. That adds up. If you are lucky, you can probably do it all for ~$7.5k-10k in parts depending on what you replace and select. Then labor to swap/assemble should be no more than $3-3.5k.
Give us a call. We can get you taken care of for WAY cheaper than that with better parts.
Www.raceprovenmotorsports.net.
Www.facebook.com/raceprovenmotorsports
Landru (06-29-2016)
Landru (06-29-2016)
I agree. At 25,500 miles I installed new PRC265 heads on my 09 and now I'm at 49,500 miles with no problems.
If dealer is replacing the entire engine including intake manifold, oil cooler and lines, dry sump tank, etc. then the price quoted is not out of line for what a dealer would charge. It is about the same as the invoice I received when GM replaced mine under warranty including all the above items. As others have said, there are probably better engine alternatives.
All the threads pretty much say the opposite. The vast majority of "fixed" heads are now getting enough miles, and rechecked without failures or excessive wear. So interesting to see why he thinks that isn't the case.
With so few miles, and so many known issues, if it failed due to an exhaust valve you could try and see if GM offers any "good will" assistance towards the cost of repairs.
are the heads ok?
Is the crank ok?
Is the crank ok?
Spun #4 main bearing. Went to LME 440 short block Msd manifold and new cam and nick williams 104 at 14,000 now doing instal my self. Budgeted for 15,000 hope to say under that.
