View Poll Results: Stock, solid urethane
Stock
2
15.38%
Solid
2
15.38%
Urethane
9
69.23%
Voters: 13. You may not vote on this poll
[Z06] What transmission mount?
Put hinsons in when I did the motor mounts. Haven't broken anything, no down sides besides cost. So far so good.
Several years ago I installed Hinson motor and transmission mounts in my 06 ZO6 in an effort to quell excessive motor/drive line movement when shifting while on track.
The Hinson mounts cured the problem with but a slight increase in nvh.
Put Hinson poly mounts in mine about 4 years ago in efforts of trying to find a cure for the dreaded wheel hop. They helped quite a bit and I noticed no added vibration etc. The only thing I had to do to them is cut the threaded studs a bit shorter because they come entirely too long, this made installing them a bit easier.
-jp
-jp
