[ZR1] ZR1 boost setup
ZR1 boost setup
Good discussion I'd like to get started, I'm doing a 2.3L LS9 on my base model C6, what kind of boost theoretically on paper would I see with the 14% overdrive crank pulley and a 2.6 upper pulley?
The car is staying stock bottom end for a while and if I'd rather not melt it to the ground if it's going to make 20# of boost.
Car has 1 7/8 headers and a BTR stage 3 PD cam.
I'm really curious to see what mine will do, i have a ported snout and ported blower, 1 7/8 kooks, BTR STG III PD cam, 14% OD and had a custom 2.95 upper made, hoping it would keep me in the 14-15 psi range.
bump! I'm looking for more input from people. Trying to see what pulley combos you guys are running and what type of boost levels you guys are seeing...
