[Z06] Erl issues
#42
Is that piston in picture #2 rocked 1/4" in the bore? Meaning is the bottom of that piston about 1/4" lower in the cylinder vs. the top? I didn't notice that looking before. If so, wow!
#43
I'm not saying ERL can't or doesn't build good engines, I'm just saying this wasn't one of them. And Ed shouldn't have had to pay anything to have it fixed properly.
#44
This was from a ford turbo build a few years back. All the paper work for the "blue printing" was filled out and checked off yet the wrong rods were installed. The bigger company's get the faster the move and in my case it's clear it was just pencil whipped and not checked. They made it right and the motor lasted less then a year before the bearings where shot. I try to do as much as I can my self anymore.
This was from a Ford only race shop not ERL. Just to be clear. Not bashing as we all are humans and can make mistakes. I have made many.
#45
I did not see the bottom half of the second picture on this phone. All can really see is the top 270 deg, and my eyes are not behaving lately
Do you have better pictures of the entire piston and cylinder? If is rocked 1/4", then that is FUBAR. No way it could rock that much with .005 clearance, unless the piston is defective.
#46
Now ERL says they're going to do a light hone on the cylinders and coat the pistons to take up the clearance.
#47
2nd Gear
The as-found report is excellent. It also confirmed my earlier comments. Ring wash. It wasn't from dry pistons, or the pistons would also be scored. Your quench is also too tight.
Who is assembling the long block and tuning this thing? Sounds pretty clear that is where the problem resides. PM me if you want.
#48
Elliot C. -
Are you somehow affiliated with ERL? Doesn't really matter to me, but just curious.
I am also curious to know more about this piston skirt coating that ERL is proposing, and why they would choose this over a hone and larger pistons. Another five thou wouldn't hurt anything.
I'd still like to see a better photo of the piston at TDC, rocked both directions. If the skirt clearance is truly five thou, there should not be as much rock as the piston appears to be tilted in the bore of the picture posted earlier.
#49
Elliot C. -
#50
Elliot C. -
They're sticking to cylinder wash as the problem. They should post a few picks of the rings if they were washed out with gas. And washing the rings would make the cylinder walls shinny.
#51
Hone and the next size up piston was my suggestion to ERL. Also suggested that Ed would make up the difference if any in the price of the next size pistons.
#52
2nd Gear
