[Z06] Building a 1300hp LS7
Okay, I'm finally going to forge my motor. After almost three years of making 734whp and 8 months of 940 whp, all on the stock rotating assembly and with no issues at all, its time for some piece of mind.
I'm currently running a small 150 shot and a Si trim head unit on 6lbs. I want to turn the boost up and spray quite a bit more. I know what I want but what do I need?
It's hard to find anyone pushing one this hard without a complete new motor, block and all. Has anyone broke stock rods, crank, pistons, block? If so, why...detination, fatigue? What are the limits on factory parts?
I'm thinking keep the block but simply replace the entire rotating assembly. The $5M question is do I need too? Pistons are a must! The titanium rods scare me...brittle. The crank though????
Can anyone attest to parts failures at certain levels and cause of failure? Thanks for the info!!!
For 1300 everything will need to be replaced. Sell the stock motor and start with a new block/setup.
I would call ERL and discuss
I've looked everywhere and can't find anything where folks have broke them. Can you point me in the right direction? At what power level can i expect the stock block to fail? Is 1000 safe?
You would have to get the OE block converted to wet M.I.D. sleeves for that power level. As mentioned above, EAR would be a good place to start. Crank might hold up, but not for long. Rods and pistons will not.
It's not just detonation and/or pre-ignition. At 1300 hp, cylinder pressure is extreme.
Turbo2L (01-01-2016)
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I don't know if I would push the stock one that hard, at least not without having a budget set aside for a new engine. I know of some guys with blowers in the 900 range on stock LS7 short blocks but even they said time was limited on how long it would go.
The highest I can remember that we went was 1086 rwhp on a twin turbo LS7. Engine was stock save for Mahle pistons with hellfire rings and one of our cam's. The rest was 100% stock but it only did dyno work and a weekend at the Texas Mile before removing it for a built engine.
I will be pushing the limits with the stock block. Hoping it will be finished up in a couple of weeks.
Mine won't be done until March but I'll keep you posted for sure.
I'm not sure where we will leaving it but I'm running twins with spray. I basically just refresh the motor and changed out the pistons to drop the compression. I will be running E85 as well.
So awesome!!! Gonna be NASTY!!! I think we can make 1300 with my set up but I'm worried about the block. We'll set it somewhere around 1000-1100whp and leave it there unless we get a call out that requires a little more. LOL Keep me posted and I'll do the same. :-)
Plenty of people have cracked the blocks at ~1000-1100rwhp. If you can build a 1300hp vette, the cost of a block is so small it shouldn't even be considered to be skimped on.
Different types of racing. My car makes over 1300hp, and when racing I wish it had 300-600 more. 1/2 mile and mile racing need big power. When you are running 1500-2000awhp GTRs and Lambos, a 1300hp vettes gets left in the dust.
