[Z06] DIY 3" Muffler Mod
#61
Congratulations! At $20/lb-ft, that is incredible value! Of course it omits the 15 hours of labor, but hey, it's a learning experience and justification for buying all that welding gear. I am thinking I should buy a welder and plasma cutter for just this reason! Did you use a plasma cutter for the cuts? Did you put your car on a lift to R2 the mufflers? Did you have to drop the cradle? Cheers!
#62
on the very edge, where you ground it down to separate the inner and outer pieces. im trying to keep the double wall tips.
#65
I think you can make some spot welds in that area and still get a high quality finish to the polished ss. I polished my single wall tips, 200-400-800-1000-1500, black compound, red compound, Simichrome. Not completely done yet, but mine look good. I wouldn't be shy at all about some metal fab on shiny areas, just takes some time to bring the luster back.
If it were me, I would think about repair first before the ordeal of replacing with another set of mufflers.
Props to you for retaining the double wall, they are nice. It could be done if cut on the outer taper at the precise line.
#66
its gunna be a b!tch but i wanna keep it. gunna be a lot of trimming and fitting, trimming and fitting, etc
#68
no problem, i havent even started on mine yet
#71
Ha, popcorn. Sorry man. The tranny is out right now, installing a Monster LT1S clutch. Also recovering from neurosurgery last week, so it might be a week or two before it's back together. I'll make sure I get a good video though.
#73
Holy **** man...take your time and relax.
#75
uh yah this isnt that important, get better first. then you can make that vid
#76
Thanks. I'm up and around, just not lifting things. The trans is out of the car at the moment, otherwise I'd make a quick clip. It's really identical to the fusion though, for which there are numerous clips online.
I'm going to grind the welds running around the muffler can smooth while the trans is out. I also bought a 21 piece polishing kit to bring out as much bling from the tips as I can, and a tube of simichrome.
Unrelated to the muffler mod, I shipped my LG Headers/x-pipe/intermediates to Swaintech for their White Lightning coating. So I'll be waiting on that stuff to return before I can hit the ignite button.
The DIY should be done in a couple days though.
#77
#79
Back from the Dead
Sorry it took so long. I made a quick video of the exhaust sound while running, pulling the fuse and putting it back in, some revs with the fuse in and fuse out.
I have driven the car for about 3k miles with the modded exhaust and I love it more each time I drive it. By far, dollar for dollar, the absolute best mod for our Z06s. ZERO drone while quiet, and HOLY F%^king Goat B@!!s loud under WOT.
I drove it 5 hours to Ocala for the wannaGOFAST 1/2 mile and it was an absolute cruise ship at 70mph. I have a friend who just gave me a drive in his C6Z, same cam, same headers (Except he has cats!), but he has a Corsa exhaust, his drones through 1600 or so pretty bad. I cannot emphasize enough that there is ZERO drone with this mod, no cats, and mine is still more civil. Cost $1000 less, more sound, no drone.
Why other people pay for exhaust systems is just beyond me. I've heard Borla and it drones like crazy, I've heard Corsa and it droned in a 100 rpm range. If you do this mod you can have an aftermarket exhaust system sound without the drone penalty, then you can go out and put new valve guides in your heads with the left over cash.
Here is the sound clip:
I spent about 2 hours editing the DIY today. It will be done this week, I just want to give people a clear "how to" with all the tips and tricks I know. And there are about 140 slides, so it's taking me a hot minute to detail everything I did. Basically, you'll become a blacksmith for an entire weekend, cutting, welding, cutting, more welding, measuring 3x, etc.
Josh
Josh
#80
https://youtu.be/1Kp6FSaY9F8
Josh
Josh
Josh B rocks
