[Z06] Need help, slammed into curb sideways.
#85
Total parts wise was a rim, axle, knuckle, bearing and inner and outter tie rod. Also had the tire hit the rear fender and cracked it but im leaving that for now. Total bill buying parts myself and then punting to chevy was $2306 total
#86
Like was said earlier, there was probably something other then the pictures showed. I was still correct for what I COULD see. You still need to make a appointment for a alignment. Have you driven it and does it seem OK now?
#87
Ok, long story short the car snap oversteered into a tall curb and nailed the back driver side wheel dead on the face while rotating. This cocked the wheel about 20 degrees inward at the front. (see pics below)
I took the wheel off and nothing LOOKS weird to me but I dont really know what to look for in situations like this. The wheel hub is cocked inward. I can take the tie rod end out and move it back into place but the tie rod wont go back in then.
2 things I think it COULD be... axle is wonky or the bearing might have gotten bent?
I am open to things to look at, not sure what to do now.
Perhaps when it's all said and done you might do us justice and spill the beans exactly how this happened in the first place.
Distracted by large partially clad hooters??? I'll let you slide for that one
#89
Hhehehehe.... yeah I hit hard and no way I could see it, even with the knuckle off the car. The brakes and bearing covered up both sides and until they wiped the crud off the sides, it was hidden completely.
Now, how it happened. I've been having the traction control need service message off and on for a few months. Maybe once every 6 weeks or so, so I didnt bother with it. (Theres a TSB). So with worn NT05s on the car turning a left turn when it was slightly wet, the traction control decided to come back on. It must have thought I was in a slide so it pulsed a brake and then sent me into a fish tail and snapped back faster than I could react to save it. Spun around and slammed the back end into the curb.
Could I have saved it, I dont think so. Should it have happened in the first place? I dont know, off camber turn on a wet road and wonky electronics, I dont think I did anything wrong.
#90
#93
No, I did not punch it. I was driving normal... maybe going 15 mph or so taking a left from a light. It didnt break traction until just about done with the turn. Maybe oil or sand on the road, I dont know but I didnt goose it or anything. but no, no hooters.
#94
#97
#98
I recently purchased a z with a similar issue but on the passenger side. The impact was at the wheel. As I got into it here is what I found. The lower control arm bent and the upper broke and the tie rod bent which is what caused the wheel to be off center and and pushed forward. the impact was hard enough that it broke the mounting tab off of the differential and cracked the spring. The frame is fine and the cradle is fine no cracks. the cv axle seems fine as well. It is pretty easy to take the cv out if you have airtools to get the axle nut off. You remove the 4 bolts on the upper control arm and the tierod end. remove the calipar and rotor, and assuming the suspension isnt bent to bad you can free the axle and get it out. check the two tabs where the diff mounts to the cradle that is a weak spot. Then put the upper a arm bolts back in see how how it lines up with out the axle. ill bet the axle is ok, it is a cv and can move alot. I ended up replacing the complete suspension assembly and I know you can find a dropout for less than $500 on ebay. bolt the new one up and get a new rim/tire and alignment. I hope this helps.
SivaSuryaKshatriya (02-22-2018)
#99
You are going to have to clean it up and take a full spread of pictures like the OP did, with the wheel off and in good light. Carefully inspect where the tub is glued to the frame. If you are unsure what you are looking at, hang it up and have it looked at by a pro. Looks like a insurance claim anyway.
#100
