C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] ls7 evacuated a piston
Old 08-30-2015, 08:22 AM
  #81
68Stang
68Stang's Avatar
I did not remove anything from the bore. I imagine there's a lot of crap in the oil pan. There was a ton in the manifold and a lot would up in cyl 5. It's resting on top of the piston.
Old 08-30-2015, 09:34 AM
  #82
JoesC5
JoesC5's Avatar
Received 1,700 Likes on 1,214 Posts
Originally Posted by dmuellenberg
Well, so much for everyone who insisted a valve head was missing.
Or those that say a solid stem steel exhaust valve is a bad choice. Looks like a confirmation on reworked heads fitted with SS exhaust valves.
Old 08-30-2015, 01:07 PM
  #83
ChevyCobb
ChevyCobb's Avatar
Well there seems to be your problem.
Old 08-30-2015, 02:16 PM
  #84
Jason913
Jason913's Avatar
i think that will buff out .
Old 08-31-2015, 07:40 AM
  #85
stew1100
stew1100's Avatar
Thank You for the pics.
Old 08-31-2015, 10:55 AM
  #86
Dubstep Shep
Dubstep Shep's Avatar
Things I'm somewhat amazed by:
The combustion chamber isn't more destroyed.
That rod is still basically in one piece.
Literally there's nothing left of the piston attached to said rod.
The pin is still on the rod.
Old 08-31-2015, 01:19 PM
  #87
stefuel
stefuel's Avatar
Originally Posted by 68Stang
Pics!!!!!
So I don't have to be missing a valve head:
#6cyl
The rod got angry at the sleeve. Sleeve shattered. Block cracked.
When you get a chance I'm sure everyone would like to see what's in the oil pan.
Old 08-31-2015, 01:51 PM
  #88
68Stang
68Stang's Avatar
I'll try to keep updating this through the tear down. Anything salvagable will be for sale.
Old 09-01-2015, 11:39 PM
  #89
SHovV
SHovV's Avatar
Straight up piston failure. I'm suprised it didn't rear the block up more.
Good lock on a rebuild.
Old 09-02-2015, 08:00 AM
  #90
LFZ
LFZ's Avatar
Looks like the SS valve here stayed in tact during this piston failure. I wonder how many piston failures there have been which destroyed the valve especially the OE hollow stem valve? So what came first...............?
Old 09-02-2015, 09:20 AM
  #91
08mojo
08mojo's Avatar
My guess is the liner failed first and water entering the combustion chamber is what shattered the piston. It's a shame no matter how it happened... Good luck with the rebuild!
Old 09-02-2015, 10:53 AM
  #92
chip4
chip4's Avatar
This low mile Z28 also has #6 cyl failure.
http://www.camaro5.com/forums/showthread.php?t=419077
Old 09-02-2015, 11:29 AM
  #93
LFZ
LFZ's Avatar
Broke intake valve too....wonder what came first.
Old 09-02-2015, 11:43 AM
  #94
Michael_D
Michael_D's Avatar
Valve float may have started the complete piston failure.Could have been detonation, could have been a few different things.
Assuming anything at this point is, well...... pointless. Just like the earlier assumptions that the failure was due to a dropped valve.
One of the things I preach around here, and for good reason, is to not assume anything, and take critical measurements. Review your findings.
Old 09-02-2015, 01:23 PM
  #95
Vette @ 71
Vette @ 71's Avatar
The loud sonic boom (backfire) heard at the time of the disaster would support a detonation as the likely cause? The pattern of destruction also seems to suggest a powerful overpressure event..
Old 09-02-2015, 08:41 PM
  #96
ATC399
Support Corvetteforum!
ATC399's Avatar
Z/28s oh ****.....
Old 09-03-2015, 09:27 AM
  #97
Michael_D
Michael_D's Avatar
Maybe......but think about the things that can cause detonation, like hot spots on a piston, and how they can get there.....
This is just all speculation. I wouldn't rule anything out but possibly space aliens at this point. I'd have to do a complete tear down and measure/test everything before coming to a conclusion.
To ls7 evacuated a piston
Old 09-03-2015, 06:42 PM
  #98
C Moe
CorvetteForum Editor
C Moe's Avatar
Default Front Page Coverage
Sorry about your engine. Thought maybe some of the front page crowd could help diagnose the problem.
https://www.corvetteforum.com/articl...ystery-ensues/
Old 09-03-2015, 11:57 PM
  #99
fpcopo
fpcopo's Avatar
Looks like #4 or 5 cylinder
Old 09-04-2015, 01:38 AM
  #100
univerz06
univerz06's Avatar
holy crap you made it to the front page...if this was reddit you`d have so much gold right meow
front page cat tax
Quick Reply: [Z06] ls7 evacuated a piston
