[Z06] Just lost a vlave in cylinder #1
St. Jude Donor '07
Yesterday on the way home my 2007 Z06 dropped a valve into cyl #1.
I have had this car since new and it has 32,500 miles on it. a little discouraged that the engine didn't last as long as the belt.
I talked to the local service manager and he says there is nothing he can do.
Does anybody have the number for the regional service manager in the central CA area?
I would just like to try and talk to a few more people before I start to tear the engine apart.
Also does anybody have a recommendation on a machine shop in my area that can rework the heads and repair whatever damage I may have in the block?
Thanks in advance
Thanks in advance
St. Jude Donor '07
If the block is cracked, does anybody know where I can get the best price on a longblock? the local dealer quoted me 12550.27 out the door
..and the 65535 dollar questions..
1. Were you unaware of the numerous LS7 valve guide threads over the last 3 years, and the solutions presented within them?
2. Did you check them but still had a failure? That would be a critical point.
Maybe you can hit up the "it's all Internet hype" crowd for a new for a new motor.
In all seriousness, sorry about your car; if you can (why wouldn't you?), please check out the guides with a wiggle test, report back on how bad they are, so we can finally shut down the nay-sayers that may have caused folks like yourself to ignore this all-to-real issue.
Supporting Vendor
Sent you a PM.
St. Jude Donor '07
The car has always run so good that I never had any concerns. I have also not been visiting the forum regularly in quite a while.
I got through to GM corporate and they gave me a case number. now I have to tow it to a dealership so that they can look in with a Bore scope and try to come up with an estimate.
Then GM will decide if they want to help out.
My main concern is that if I do the work myself and maybe go with aftermarket heads that if they ever do a recall on this, I will get stiffed. (more like I know I will)
so I am just trying to get the documentation down for that long shot.
If I do the tear down, I will update you on the guides.
impossible....GM says 2007 Z06 are not in the affected group.
oh yeah, GM is a fking liar.
paid out of pocket to fix mine....didn't want the $15K bill.....good luck
Godspeed OP.
I know some people believe that GM is lying when they say only certain years were affected by the machining error, but all that statement did was address a machining issue, not about excessive valve guide wear. They never said other years wouldn't have valve guide issues or drop a valve. Obviously other factors are involved other than just the machining issue.
Thanks in advance
Thanks in advance
I would be shocked if GM helps you out just from reading other cases on this site. I hope they do it's a shame that they continue to get away with this. I bought my car used and had to pay additional to make my 10k mile care reliable. Guys on this site saved my butt, thanks again. You bought your car new, probably paid $65k plus. Engine didn't make it 33,000 miles. This is so wrong on all accounts.
Best of luck to you!
St. Jude Donor '07
so, the next question, if I get a new GM longblock and heads, will I have the same issue. Or am I better off getting aftermarket heads?
If aftermarket: which ones? not looking to add HP just reliability.
Also, the 2 dealerships in my town are $750 different from each other on long block and heads, so I will be doing some shopping around
Received 1,373 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
You'll have to replace the dry sump oiling components to keep the metal out of the new engine. As mentioned, no matter what GM tells you contact American Heritage Performance and see what they say before making a decision, most definitely worth the phone call.
Well, for starters, I see you chime in frequently in these threads, complaining about all the "Chicken Littles / Sky is Falling" folks like myself, all the while boasting about how your car, a 2013 with barely 10K miles IIRC, is still perfectly fine.. OF COURSE it is, they don't fail at 10K - but they do fail at 20K, 30K or 50K, especially if tracked.
I am angry because yet another fellow CF brother is out $15K, not to mention the drama of having his car out of service, and potential additional damage sloppy GM techs may inflict on his vehicle (hopefully he is near Able Chevrolet, or AHP), all for something that could have been prevented.
This is simple - WE didn't build these cars - WE didn't do a crap job machining the heads - but when they are out of warranty (or even if they are in warranty), WE, as a CF brotherhood and community, have a responsibility to do what we can to help inform others that don't understand this issue - not to post snide comments / responses about "Internet hype" to the people that are trying to keep history from repeating itself.
