C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 2006 w/24k miles Obliterated Valve !!!!!!@
Old 03-22-2015, 01:35 AM
badass7
badass7's Avatar
Default 2006 w/24k miles Obliterated Valve !!!!!!@
OK, purchased an 06 Z06...was at 6k Rpm and PUFF ......white cloud of smoke and crunching noise in engine!!!
No official diagnosis but what I've been reading about and. Dreaming about her since purchasing in *Oct has come ****ing true !!!!
Old 03-22-2015, 03:59 AM
jetpowr
4th Gear
jetpowr's Avatar
Default same old thing
Tear down engine and let up know what is revealed..
Old 03-22-2015, 07:35 AM
C6z06man
C6z06man's Avatar
Definitely sounds like a dropped valve. did you look around the engine for signs of a hold in the block? Any fluids leaking out?
Old 03-22-2015, 08:31 AM
badass7
badass7's Avatar
At first no fluid at all. Then when put up on flatbed oil and coolant bleeding out all over from back side of engine.
Old 03-22-2015, 08:37 AM
badass7
badass7's Avatar
Also, had an Audi R8 trailing me and they believe they saw debris shoot out of exhaust along with Puff of white smoke.
At shop soon for tear down.......verdict awaits.
Old 03-22-2015, 08:44 AM
GeneSch
GeneSch's Avatar
Be sure to post up pics
Old 03-22-2015, 08:53 AM
Josh B.
Josh B.'s Avatar
Sorry to hear about your engine. What mods were done to the car? I do hope that you document everything with as much data and pictures as possible.
Old 03-22-2015, 09:25 AM
badass7
badass7's Avatar
On way to dealership
Old 03-22-2015, 09:29 AM
badass7
badass7's Avatar
What kind of ****ing sports car with 24k Miles on the clock drops valves all day long like these LS7's?? And GM is going to try and tell us that there is no problem....that this is an isolated prob. Gimme a FKN break.
Old 03-22-2015, 10:15 AM
fstphx
fstphx's Avatar
Flash stick tune before warranty adjuster gets to it.
Old 03-22-2015, 10:29 AM
badass7
badass7's Avatar
shoiuld have gotten Heads checked!!!
Old 03-22-2015, 10:43 AM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Originally Posted by badass7
Can they tell if has been reflashed to stock tune??
Yes.
Sorry to hear of your mishap.
Old 03-22-2015, 10:53 AM
3LZZ06
_"SCOTT"_
Support Corvetteforum!
3LZZ06's Avatar
Unfortunately with a tune it's going to cost you a few dollars.
Best of luck with the claim, maybe I'm wrong if GM decides to be generous.
Old 03-22-2015, 11:05 AM
badass7
badass7's Avatar
Car is bone stock w low mileage. No way this should've happened. I will be signing up for class action!
Old 03-22-2015, 12:09 PM
moose.b3
moose.b3's Avatar
OK, purchased slightly modded '06 Z06...was at 6k Rpm @ 150mph and PUFF ......white cloud of smoke and crunching noise in engine!!!
So you've had the car since Oct. and didn't have the heads checked? Must have thought it was internet hysteria. Sorry for your loss.
Old 03-22-2015, 12:20 PM
Vegas1500
Vegas1500's Avatar
Old 03-22-2015, 02:51 PM
80atez
80atez's Avatar
Bummer. I dont think youll be covered. And youve admitted here you know about the tune and want to commit fraud. I mean i can see why, but facts are facts. If i were you i would let chips fall where they may without an attempted coverup.. No pun intended. I really would but i understand $ is a big factor.
So were you tracking the car or street? Thats really fast for either.
To 2006 w/24k miles Obliterated Valve !!!!!!@
Old 03-22-2015, 05:39 PM
badass7
badass7's Avatar
A car w 20+k miles should not just blow like this Let it happen to you big $$ and see what you would do.
Old 03-22-2015, 05:43 PM
badass7
badass7's Avatar
Never tracked this car. Was just opening her up on a wide open highway in middle of nowhere.
Old 03-22-2015, 06:08 PM
Evolution
Evolution's Avatar
Disagree with the fraud statement. It's not fraud if the tune didn't cause the problem. If it is a valve problem, they can't say the tune dropped the valve, look at all the cars that have problems. They will, however, try and not cover it due to a tune. To me, it's the dealer who is committing the crime here. Over and over dealers deny or try and deny claims due to mods, that didn't cause a thing to happen.
I'd spend the money, return the car to a stock tune, hope they don't say anything about the long tubes and fight for a fix. With it being a possible expensive engine fix, I'd even swap out the long tubes if it was me. And if you do take the long tubes out, and if there are pieces from the engine in them, put them right back into the stock manifolds. Just my 2 cents though.
Quick Reply: [Z06] 2006 w/24k miles Obliterated Valve !!!!!!@
