[Z06] Any recommendations on a fuel pump e85 compatible?
1st Gear
I am wondering which fuel pump would good that is e85 compatible, i recently got a flex fuel kit and the injectors upgraded so i could run e85 on my c6 z06 (598whp) but did not upgrade the fuel pump. i was told that the stock fuel pump is compatible with e85 for some time but eventual it will fail. i am going to be changing the clutch in a month or two so i think i should upgrade the fuel pump at the same time. Any recommendation are greatly apricciated.
Thank you,
Edgar
Thank you,
Edgar
