[Z06] cam ? 242 250 114.0
cam ? 242 250 114.0
have my cam card from comp cams. cam is from TSP. what do'es all that mean. valve adj. gross valve lift duration @, tappet lift, valve timing open/close @.050 int:btdc abdc, exh:# bbdc#, now lobe lift #s
Looks like a medium size cam with an overlap of +18.
It should rock and roll the car pretty good at idle.
((intake+exhaust)/2)-(lsa*2)=overlap
OEM LS7
211 / 230 @ .050, .591 / .591 lift, 121 LSA
((211+230)/2)-(120*2)
220.5 - 240 = -19.5
Katech Torquer 116
220 / 244 @ .050, .615 / .648 lift, 116 LSA
((220+244)/2)-(116*2)
232 - 232 = 0
Lingenfelter GT19
227 / 239 @ .050, .678 / .688 lift, 114 LSA
((227+239/2)-(114*2)
233 - 228 = 5
Stalker - 224/246 115
((224+246)/2)-(115*2)
235 - 230 = 5
Lingenfelter GT17
228 / 232 @ .050, .621 / .630 lift, 112 LSA
((228+232)/2)-(112*2)
230 - 224 = 6
Katech Torquer 110
220 / 244 @ .050, .615 / .648 lift, 110 LSA +004
((220+244)/2)-(110*2)
232 - 220 = 12
Lethal - 232/250 113
((232+250)/2)-(113*2)
241 - 226 = 15
Katech K501 Camshaft
235 / 251 @ .050, . 657/ .660 lift, 113 LSA
((235+251)/2)-(113*2)
243 - 226 = 17
YOUR CAM
242 / 250 114 LSA
((242+250)/2)-(114*2)
246 - 228 = 18
Punisher - 236/256 111
((236+256)/2)-(111*2)
246 - 222 = 24
Lingenfelter GT21
243 / 259 @ .050, .663 / .702, 112 LSA
((243+259)/2)-(112*2)
251 - 224 = 27
Striker - 244/256 110
((244+256)/2)-(110*2)
250 - 220 = 30
Katech GM World Challenge camshaft
239 / 251 @ .050, .570 / .570 lift, 107 LSA
((239+251)/2)-(107*2)
245 - 214 = 31
Katech GM Stage 3 Camshaft
233 / 276 @ .050, .630 / .630 lift, 107 LSA
((233+276)/2)-(107*2)
254 - 214 = 40
OEM LS7
220.5 - 240 = -19.5
Katech Torquer 116
232 - 232 = 0
Lingenfelter GT19
233 - 228 = 5
235 - 230 = 5
Lingenfelter GT17
230 - 224 = 6
Katech Torquer 110
232 - 220 = 12
241 - 226 = 15
243 - 226 = 17
YOUR CAM
242 / 250 114 LSA
246 - 228 = 18
246 - 222 = 24
Lingenfelter GT21
251 - 224 = 27
250 - 220 = 30
245 - 214 = 31
254 - 214 = 40
OEM LS7
220.5 - 240 = -19.5
Katech Torquer 116
232 - 232 = 0
Lingenfelter GT19
233 - 228 = 5
235 - 230 = 5
Lingenfelter GT17
230 - 224 = 6
Katech Torquer 110
232 - 220 = 12
241 - 226 = 15
243 - 226 = 17
YOUR CAM
242 / 250 114 LSA
246 - 228 = 18
246 - 222 = 24
Lingenfelter GT21
251 - 224 = 27
250 - 220 = 30
245 - 214 = 31
254 - 214 = 40
OEM LS7
220.5 - 240 = -19.5
Katech Torquer 116
232 - 232 = 0
Lingenfelter GT19
233 - 228 = 5
235 - 230 = 5
Lingenfelter GT17
230 - 224 = 6
Katech Torquer 110
232 - 220 = 12
241 - 226 = 15
243 - 226 = 17
YOUR CAM
242 / 250 114 LSA
246 - 228 = 18
246 - 222 = 24
Lingenfelter GT21
251 - 224 = 27
250 - 220 = 30
245 - 214 = 31
254 - 214 = 40
Here's more info.
Overlap - 18
IVC ABDC - 52
IVO BTDC - 10
EVC ATDC - 8
EVO BBDC - 62
0.050 DCR - 9.6
On an otherwise stock motor, you are losing .26 pts of DCR at 0.050.
Overlap - 18
IVC ABDC - 52
IVO BTDC - 10
EVC ATDC - 8
EVO BBDC - 62
0.050 DCR - 9.6
What the hell does all that mean? Try-in to learn as much as i can, an what you just said, I feel even more dumber then be for. Thank you anyway. richard. Dam should of paid more att. in mechanical engineering, when i was in school. well that was a long time ago.
Its basic valve timing events based on the cam specs. Most important parts are overlap (18 degrees) and IVC (52 ABDC). The 18 degrees of overlap means its a fairly large cam and you may have some driveability issues compared to stock (mostly on lightly loaded conditions). With the IVC at 52 degrees ABDC, you are losing dynamic compression compared to the stock cam which is going to soften up you bottom end a bit.
I bought an alky kit, now looking for a hell cat pump...
just gonna run a small blower cam with stock street manners... and some springs...
that's good for 750-800rwhp on 93+meth
