[Z06] WCCH K501 Build
#143
Comparison of YOUR new to old will be interesting and more discernable. Hopefully you pick up good power from those headers. I've got stock manifolds myself right now. Not too many of us out there!
#147
Originally Posted by reasonable suspicion;1589314983[B
]I dont believe its a worthless comparo, but to each his own.[/B]
Ill pm you the results Josh.
Ill love to know the results. I'll appreciate a PM with them. Thanks!
#148
Ill have to agree with you. The only way that it will seriously screw the results would be (for example) a Mustang Dyno vs Dyno Jet, but same type of dyno it will be very close specially if they are SAE to SAE readings.
#149
#150
Awesome gains man I went without cats, I wonder if that makes a difference at all (other than the persistent "rich" smell from my exhaust...)
Thanks for the kind words, I'm happy with the way mine came together. I like the paint on your FAST intake, in hind sight I would have painted the MSD, but I wasn't focused on aesthetics at that point. I drove mine last night and I'm noticing some mild surging around 60mph in sixth. 70mph, no surging, but definitely some surging at highway speed. Interstate speed is fine. How is the driveability with your K501?
#151
Cant you paint the msd while its on the car, I know I have seen threads where people have painted the fast after install......maybe smooth the logos off the msd and paint it yellow????? That might be just the trick to make it look awesome on your car!!
Enjoy the car, and be safe!
#152
#153
I love the way this cam drives. It makes great power with very little compromise. Sure there is some mild surging but it's nothing to extreme. Mine is exactly as you have described. Some mild surging in sixth at 60 but very clean by 70. I can drive mine in sixth at 65 but if I come to a hill I shift to fifth when I feel a mild surge. Some people can't stand any surge at all but to me this cam falls in a very comfortable spot on the give and take spectrum. I would pick it again. It's got a great sound at idle too.
#154
Congrats on the build. You are making it very hard for me to wait on getting my car back from Katech! I have the K501 cam as well, and am getting the car back at the end of April.
My car has LG 1/7/8 headers, no cats, and dual QTEC cutouts...
Hopefully it will be loud
Katech #76
Katech #76
#155
Josh, could you go into the details of how this combo drives with the K501 and the MSD/NW102? What clutch do you have? In around town driving what RPM do you use as your minimum. At what speed/RPM can you cruise on the highway in 6th? I know this can vary based on the quality of the tune.
I hope to have my build done in June, similar to your components including DeWitts.
Thanks for all your PM help, too.
#156
Now that the car has been together for almost a year I can give some better details on the drivability of the K501. Best way to summarize: the car is my daily driver, it's extremely drivable. Now, I'm 34 years old, I have 80's/90's rock/metal in my stereo at the moment, so "driveable" for me might be "unacceptable" for someone listening to Lionel Richie or KC and the Sunshine Band.
I installed almost all the HCI components at once, so I can't really tell you how installing the MSD/102 or WCCH heads/K501 would affect the car independently from each other.
With the K501 and the tuning touch of Mike at www.vengeancepcm.com, I keep rpms at 1500 or so in parking lots, this cam will require you to do about twice as much clutch work to keep things civil, compared to the stock cam, if there's a school zone I stay above 1700 rpm in second gear at about 20 mph. Any less, and it will be a ticket to surgetown. Third gear is settled by about 1400-1500 around 30 mph'ish, Fourth gear will tolerate about 1200-1300 around 40 mph. Once above 45 mph, fifth and sixth will be "ok" with whatever rpm you throw at them, on flat ground. If you are lugging it around in sixth gear around 50 mph you will have to downshift to fifth or fourth edit: on uphills or you will encounter surging from the additional load. At 60 Mph downshifts are no longer needed at all, the cam is now very smooth at 1200, uphills, downhills, flatground. At 70 mph, the cam feels stock again, not a single hiccup, ZERO surging.
At anything below 70 mph, anyone who has driven a cammed LS7 will be able to tell the car has a cam in it, don't believe the "zero surging" claims made by some major people on this forum. The surging is there, hiding in the shadows, and a properly calibrated seat of the pants butt will feel the faint feeling of towing a trailer with a rope sensation that ultra minor surging feels like. It's not full blown head jerking surging, it's just a minor interference of the smooth V8 firing order of the stock cam. The good news...give it a couple months, and you'll be a absolutely acclimated to it. But to avoid any kind of relapse, it's probably better that you go ahead and never drive a stock cammed car ever again, because you will instantly find out just how many "drive arounds" you have created in order to tame your cammed beast. Driving adaptations like "California rolls" through empty four way intersections, slipping the clutch while in parking lot situations, higher rpms around town. With the stock cam, you can pimp slap the pedals like a complete noob and it won't bite you. You just can't do that with a K501.
I cruise between 62 and 70 mph. 62 is smooth, MPG is still high. 70 is stock silky smooth, MPG is still great.
I have the Monster LT1-S with the lightened flywheel option. The monster uses a stingray twin disc, so it is factory smooth when being slipped, pedal effort is same as stock, basically it's as good as stock, except I gained 9 rwhp and 7 rwtq with the lower moment of inertia of the smaller diameter clutch. The lightened flywheel makes driving the LS7 an absolute delight, throttle blips actually make the tach needle move, rev matching for downshifts is now a complete breeze and makes me feel like a pro (im not!). The only downside, I use a minor throttle blip from a dead stop to help give the flywheel some added inertia to get the car rolling. I am sure some additional clutch slip would achieve the same result, but I have not perfected that yet.
Because there will be additional clutch slippage needed when installing the K501, I give this clutch and light flywheel my highest recommendation. It's perfect for the combo, the light pedal effort and organic linings make parking lots very smooth, zero chatter. Do not get a metallic lining, they cannot claim zero chatter, and for me, chatter is annoying, especially when you hit the left pedal 50 times while commuting. Last caveat, the stock LT1 clutch discs are unsprung hubs, so you will hear some gear rattle in neutral, clutch out. But it's a very faint sound while tranny is hot, and extremely faint with tranny cold. My .070" lifter preloaded valvetrain makes almost as much noise, so it's a moot point. Especially if you have headers, you will barely even hear it, and you have to be trying to hear it.
I hope that helps. I look forward to learning more about how your combo turns out!!
Josh
#157
Josh, excellent write-up on your K501 build. I fall in the latter music group as I started racing Datsun (anyone still remember that name?) 510's in SCCA when they were new. My cam'd V8 experience is with a Ford NASCAR 358CI with 9:1 CR which dyno'd at 605HP@7200RPM with 750 CFM carb and a full race torque cam - it was fine by 2500 RPM around the paddock (redline was 8400 if you wanted frequent rebuilds, or 7600 which is what I used).
I've read a lot of write-ups on cam'd street car drivability. The parking lot experience you mentioned agrees with what my prospective builder indicated. I'm going with a McLoed RXT dual disk clutch and SS flywheel, to improve low speed surge. WIth my build (similar to yours) I should easily achieve my performance goals, primarily to top 200 MPH without wind aid in the Mojave Magnum (1 1/2 mile trap speed). With the Mojave events, you get your 1-mile trap speed time as well. I'm hoping to improve that by about 12 MPH over my current stock configuration (stock acceleration drops off once you shift into 5th). I haven't done any 1/2 mile events yet, but we have a few of those out here, so I will get to some.
#159
#160
Thanks Dave. Your combo sounds awesome. The Mojave Mile sounds intense!! Have you considered modifying the factory trans with ZR1 5th and 6th ratios? Those might be better suited to events such as the Mojave Mile where WOT shifts between 4th and 5th can make the difference between winning and losing. You're right, the jump from 4th to 5th in our Z06 ratios makes the LS7 fall on its face, then slowly come back to life. The problem though is that the Z06 just lost 1000' of runway trying to regain the momentum it just lost. A ZR1 5th gear would put the LS7 right back into the meat and potatoes of the powerband, not the vegetables...
I am aware of the two ZR1 6-speed gear sets and they'd definitely be better in the mile. Maybe later!
