[Z06] shifter rattles when I get on it?
if you remove the shift boot by turning the silver part on the shifter **** pull the shift boot down and tighten the allen bolt that holds the shift **** on the the shifter it will prolly stop
I dropped a random nut into the opening of the shifter handle for weight. I then added some RTV for dampening. It took care of the issue on mine along with tightening the allen bolt.
Mine too but it is aftermarket because the huge round metal ball(read megaphone) that threads on to the shaft. i hate it.
Now I'm looking for a MGW. They make the best shifters imho
Pull up your center console and try tightening the bolts that mount the shift box to the tunnel. You may have the old solid brass mounts on the shift box as I do (mine doesnt rattle though)...in 2010 they went to rubber bushings found in the base C6 to stop the rattle some experience. Aftermarket shifters and ***** can make this worse.
Banned Scam/Spammer
Get a mgw shifter you will be happier and no more rattle tattle rattle.
