[ZR1] 4l80e swap. Anyone know of a working harness/controller
Might 4l80 the car this winter. I hate shifting into 5th at these half mile events. Feels like I'm loosing a couple mph just on the slow shift.
Anyone know of a working harness/ controller to get it functioning. Dsx only has the z06 set up done right now.
Putting a 4L80 in a your car would be a mistake. Ive been down that road a few years back. The only place a 4l80 might be needed is 1/4 mile drag racing and I woukdnt want one for that either.
You have to permanently cut up/hack/beat the tunnel of the car to make it fit. Don't let anyone kid that it just takes "a little" cutting.
An auto trans makes a lot of heat. ZR1's have enough issues trying to keep the motor, blower, etc cool, adding another heat generator only complicates the issue.
There are other options you could go if you don't like throwing 5th.
Putting a 4L80 in a your car would be a mistake. Ive been down that road a few years back. The only place a 4l80 might be needed is 1/4 mile drag racing and I woukdnt want one for that either. You have to permanently cut up/hack/beat the tunnel of the car to make it fit. Don't let anyone kid that it just takes "a little" cutting. An auto trans makes a lot of heat. ZR1's have enough issues trying to keep the motor, blower, etc cool, adding another heat generator only complicates the issue. There are other options you could go if you don't like throwing 5th.
For what you want to do, a 4L80 wouldn't make sense unless you pair it with a 3.15 rear end.
You can use a PCS, but it won't end up with true factory style integration like the setups I do. I could probably make a ZR1 work, but it'd be tough and take some testing because of the uniqueness to the ZR1.
There's a lot of BFH work involved with making a 4L80 fit.
For what you want to do, a 4L80 wouldn't make sense unless you pair it with a 3.15 rear end. You can use a PCS, but it won't end up with true factory style integration like the setups I do. I could probably make a ZR1 work, but it'd be tough and take some testing because of the uniqueness to the ZR1. There's a lot of BFH work involved with making a 4L80 fit.
We're putting a turbo 400 in our z06 so I'm fairly familiar with what it takes to get those in the back I don't mind the chopping up. She's my racer and gets treated as such haha.
Getting the thing wired in and working correctly because of the ecu is what I'm trying to figure out. I know some one did a 4l60 on one already but can't find much info on it
Plus I need to pull it to buy a new clutch now and only options are the silly expensive rps quad or a tilton. I don't really want to drop the money on a quad either to still have issues with 5th either
Former Vendor
was planning on matching a rear final up to get it working correctly.
David Donnals
Owner/Engineering
Similar but in a beefier trans. 4l80 probably won't work looks like the final we will need to do the speeds is gonna get chewed up. Don't want to go th400 either. Looks like I'm rebuilder the tripple to thier HD
I don't think you will be able to keep a c6 rear together with that kind of tq. I would not take the step down in strength there. Maybe try the Spec E trim?
