[Z06] The "Who did your heads Registry".
#161
England Green in Houston did all the work on the car.
~18,000
Reworked and ported stock heads
Bronze Valve Guides, SS Exhaust Valves, Repolished Stock Ti Intake Valves, Brian Tooley Dual Valve Springs w/Ti retainers, Brian Tooley Chromoly Pushrods, Comp Cams Rocker Trunion Kit
Mainly used for Track/Auto-x
Car currently at 20k, plan on rechecking around 35k
5W-30
~18,000
5W-30
#163
RamAir972003 (12-04-2016)
#166
Its a garbage formula meant to assist with meeting epa standards by reducing or removing all together the anti wear substances that it used to contain. if we were talking pre 2003 mobil 1 then yes maybe it would still be my oil of choice.
#170
I have a thread on it in this section of Forum. If interested and can't find it I will post the report for you.
DH
#173
What's the significance of lead content? Newer bearing don't use lead in manufacturing...Piston rings maybe? Fuel contamination? I use amsoil 10w30 with zddp and have been for almost 30k miles (since ive owned the car) but I've got a forged bottom end. I change oil every 5-6k miles and I beat the hell out of my car, not even going to lie. Only issue to date was a broken comp valve spring after 4 years and 30kish miles of abuse. Cheap spring, should have went BTR from the beginning but I was a tight *** with the $$$.
#175
CHE bushed rockers
Manley Nextek .700" springs w/Ti retainers
Morel lifters- cannot remember part number
Cam spec: 231/246 .653"/.652" 115+3
The car's current mileage is 13,062.
jswilke (12-04-2016)
#176
So basically bronze guides are not a fix then just a bandaid...just like I suspected. Chad that was on the forum told me the same thing but he did say the moldstar guides were the fix after pulling another customers heads with moldstar...we are getting closer and closer on seeing the real fix for thus issue thanks again hopefully gm is reading this.
#177
I am almost done ×with my build Darin Morgan did use bronze guides in these set of heads lets see after 10k how they are from now on i am doing oil analysis every time i do oil change i recommend everyone else do the same...thanks
#178
What did WCCH have to say about it? How are the CHE bushed rockers holding up?
#179
There could be a reason Katech swapped from using polished OEM intakes to their TiMo intake valves as they use WCCH and the CHE bronze guides in their builds. (finer stem finish and coating compatible with bronze guides on Ti valves.)
That does not deal with the OEM exhaust valves used in their builds with CHE bronze guides, though.
#180
2006 with 40k and a wiggle test (DIY) showed a few valves at the limit. AHP reworked the heads with Moldstar90 guides and .030 mill. Install was DIY with .040 head gaskets.
AHP was great to work with and provided sound advice and suggestions before and after the sale.
