[Z06] C7Z hits 0-60 in 2.95 seconds
I just read a report on CNN, quoting Chevrolet, that the C7Z will be under 3 seconds 0-60--with the 8 speed auto. About 3.4 with the manual.
Don't think I'd want a torque converter in a Corvette intended for road racing.
I'm wondering how quick the auto will overheat on the track (the C7 Z51 has had some issues reported) . . . .
Manual C7 Z06 only beats C6 Z06 by 0.2 sec and 1 mph in 1/4. Auto is faster ET but same trap speed of 127 as the manual.
Note that the time gap between C6 and C7 at 60mph is bigger than the time gap at 1/4 mile for both the manual and auto versions of the C7.
So, the C6 is faster from 60-126 than the C7 based on GM numbers released for the C7 and the Car and Driver test results for the 2007 C6
Z06.
Unless, of course the GM numbers just released are conservative...
Z06.
C7 Zo6 hits 60 in 2.95 seconds - Dodge (Charger) hellcat 2.9 flat
http://jalopnik.com/dodge-charger-he...n-2-1641256969
Looks like the propaganda wars commence
The poor old 640hp viper is so slow
And the CHarger Hellcat -- the 4 door dodge is reported to be faster.
Even so, Ranger beat the Hellcat's 1/4 mile time in a stock C6Z06.
There are probably a dozen threads on this in the C7 Z06 section. All worthless, means nothing on the street. But fun to read. Auto should be quicker, not faster (or used be that way). Knowing GM, they are likely taking #'s from a few runs and posting bests. A8 and M7 same trap speeds...hmm
Does anyone know how the c7z did these 0-60? was it at a drag strip with the additional traction or on the street? How do they launch all that power without spinning? traction control?
Z06.
Z06.
You re dead wrong
Z06.
Z06.
That's amazing when you think about it. You will be able to buy a 10 second car right off the showroom floor.
And...I believe these numbers are SLIGHTLY conservative! I mean 127mph trap speed is rather lax IMO. I know that thing has MORE than GM is releasing. Cant wait to see all the test!
base LS3 4.2 seconds, 12.6@115
427 vert 3.8 seconds, 11.8@123
Z06 3.7 seconds, 11.7@125
ZR1 3.4 seconds, 11.3@131
BUT, the GM specs for the 2006 Z06 was 3.5 seconds 0-60 and 11.5@127.1 in the 1/4.
Install the tires from a C7(base C7 to base C6, C7 Z06 to C6 427 vert, C7 Z06 to C6 Z06, C7 Z06 to C6 ZR1) on any of the above(you don't have to be a rocket doctor to do that "mod") and see where the numbers fall. I think you will find the delta becomes very, very small between a C6 and a C7.
A big chunk of the performance gains with the C7 are the results of a decade newer tire technology.
it amazes me how many people can't figure out this simple rule of thumb...the right tires make a world of a difference and the GY are about as crap a tire as they come.
