C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Shifter Rattle in 2007 Z06-will MGW shifter fix??
Old 07-21-2014, 10:23 AM
pikemike428
pikemike428's Avatar
Default Shifter Rattle in 2007 Z06-will MGW shifter fix??
Trying to find a fix for this. Anyone who has installed the MGW has it fixed it? Any other shifter fix this issue??
Really annoying and cheap feeling in a car of this level of performance.
Old 07-21-2014, 10:19 PM
pikemike428
Nobody has any fixes?
I see some replace with a newer standard corvette lower shifter box with the rubber bushings, but anything else that works?
Old 07-21-2014, 10:52 PM
rockinSeat
rockinSeat's Avatar
I had it fixed under warranty. Z06 didn't have the rubber bushing till maybe 08 or so and then all vetted shared same shifter is what service advisor told me. The factory part fixes it. I think you might be able to just get the bushing if you want t o save $. Sorry I don't know about the mgw.
Old 07-21-2014, 10:54 PM
ht600
ht600's Avatar
The MGW shifter fixed my rattle. I have the lower box and shifter.
Old 07-22-2014, 02:15 AM
Zoxxo
Zoxxo's Avatar
1. The factory part (update) *might* fix it. Might not. This has been a notoriously difficult thing to quantify.
2. He has a 2007 which, if still stock, has the metal "bushings" on the shifter box; they are not replaceable.
George (MGW) has gone to *great* effort to nail down the rattle issue. The latest version *should* fix it (if not, at the least, make it a lot better.) My 2007 had a awful rattle when new. The latest MGW is on my car now and there is zero rattle. But I wouldn't buy the MGW with the idea that it "promises" to fix things. It can't. But it *probably* will.
Hang on to those original metal-bushing shifter boxes - they'll be hard to come by in the future and will be desired by all the purists going for those 100 point show cars.
Z//
Old 07-22-2014, 07:34 AM
Fisch
Fisch's Avatar
The MGW shifter (latest version w lower box) stopped the rattle in my 06z, great product & easy install.
Old 07-22-2014, 10:08 AM
Lawdogg
Lawdogg's Avatar
My '07 was fixed under warranty when the car was new. There was a service bulletin on it.
Old 07-22-2014, 11:11 AM
skudlw
skudlw's Avatar
So was mine. Got the updated shifter from my Chevy dealer.
Old 07-23-2014, 10:21 AM
pikemike428
So does anyone with the new MGW box with the lower section have shifter rattle?
Thanks for the replies guys.
Old 07-25-2014, 04:53 PM
WhiteKnight
WhiteKnight's Avatar
Default If you go MGW get the latest model with lower box
I first tried the current model MGW shifter on my stock lower box. I had rattle under higher RPMs. I then bought and installed the MGW lower box and no more rattle. If you go the MGW route make sure you buy the latest model shifter and the lower box. I believe MGW will now only sell the shifter with the lower box as one unit new for this reason.
Old 07-25-2014, 08:30 PM
pikemike428
Well that's great to hear!
Thanks for the review.
Old 07-25-2014, 11:14 PM
TTZ06VETTE
TTZ06VETTE's Avatar
MGW pistol **** with old style MGW kit worked for me.
Old 07-25-2014, 11:42 PM
telly444
telly444's Avatar
I have the mgw in my 07. it's good but not sure if it's 400 dollars good. really high quality product tho. best shifter I've ever seen hands down. I've had hurst, pro 5.0 and steeda. MGW is way better than them all. I didn't find too much difference from the stock Z shifter.
Old 07-26-2014, 12:09 AM
Vegas1500
Support Corvetteforum!
Vegas1500's Avatar
Bought the new GM shifter as per service letter..........good ever since.
Old 07-26-2014, 10:39 AM
EnginerdVT
EnginerdVT's Avatar
I have my stock lower box and shifter laying around from my 08 that never rattled. Setup has 12,500ish miles on it and is in great shape. PM me if you're interested in it. I swapped to the latest MGW this spring. The install was really simple and it's a more solid feeling shift. Haven't missed 3rd since and the 1st to 2nd grind you get with a cold trans in the morning is completely gone as well. I'd recommend going with the MGW, hands down, if you want to go shorter/notch-ier. If you're looking for the same shift feel of stock, hit me up or look for another new version GM shifter. Good luck!
Old 07-26-2014, 02:14 PM
pikemike428
Thanks!
Going to wait until the end of next month and decide what I want to do. $400 for a shifter is a lot to pony up for the new MGW, but I could see myself doing it if it fixes this god awful rattle, and feels much nicer.
I'm told, the MGW, Michelin pilot ss, WCCH or AH heads, and DRM Bilstein shocks are the top 3 mods to make a Z06 perfect.
To Shifter Rattle in 2007 Z06-will MGW shifter fix??
Quick Reply: [Z06] Shifter Rattle in 2007 Z06-will MGW shifter fix??
