[Z06] What is the LS7 top of piston to deck clearance?
exactly!
watch this vid below
Received 2,062 Likes
from the service manual. Cylinder head deck height-measuring from the center line of the crankshaft to the deck face- 9.235-9.245 in
exactly!
Checking piston to block deck clearance.MP4 - YouTube
exactly!
Using calipers to measure depth when the expected dimension is small is the wrong tool for the job. Use a depth micrometer if you want accuracy. To find out piston movement in the bore, move the dial indicator to the edge of the piston that is perpendicular to the wrist pin and rock the piston. For greater accuracy, use a tenth indicator instead of a 0-1"
Should be plus five. It's always good practice to check all four corners before pulling the rods out. Then you know if you might need to hone the mains or re deck the block, or both to square it.
