C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Front tie rod needs replacing???
Old 04-19-2014, 06:56 AM
kotik
kotik's Avatar
Default Front tie rod needs replacing???
Car is 08...
Went to get wheels balanced and mechanic noted that passenger side wheel has very minor play when held at 9 and 3 and moved. They told me its a tie rod (its a wheel shop, so not real mechanics).
Ok, less than a year ago i had minor misshap and the tie rod was replaced... So y is it out again? Maybe it just needs to be tightened up? Its $100 for the part here in germany...
Old 04-19-2014, 07:28 PM
2k Cobra
2k Cobra's Avatar
Having play in tie rods is not a good thing.
If it was my car, I would have an alignment specialist look at and get his opinion.
Good luck with it, 2k
Old 04-21-2014, 08:42 AM
kotik
kotik's Avatar
This was the wheel alignment shop. Im in germany, so they r not familiar with vettes. Said some play in the tie rod. Im just curious if this play is due to it being not tightened up when i had it replaced a year ago.
Old 04-22-2014, 01:58 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Do you track the car at all? The heat from the brakes can destroy those things in no time flat.
Even the bump steer kits will have to have the ends replaced from time to time....it is for sure a wear item, more so now than ever that they got rid of the grease fitting on them.
Old 04-22-2014, 07:17 PM
Z06Ronald
Z06Ronald's Avatar
I see that you are located in Cologne (Köln), that is not too far from Callaway Competition in Leingarten.
Here's the link with their contact data: http://www.callawaycars.de/index.php/contact-us
Good luck!
Old 04-23-2014, 01:24 PM
kotik
kotik's Avatar
I do track, and generally drive north of 120mph.
Ok, i was just curious. My m3 had 70k miles and never had this issue.
I got replacement on the way
To Front tie rod needs replacing???
Quick Reply: [Z06] Front tie rod needs replacing???
