[Z06] clutch
I disagree. Did my 1st two clutches on jackstands.
99% the same. If you have done a c5 then the c6 is probably a bit easier.
Engine cradle has to come down they done away with the access in the bell housing forgot what year this started my tech had to drop both cradles.
z51vett
Doug
z51vett
Doug
Yep, they disconnect right under the car by the header on passenger side.
This link should give you a general idea of what's required to do the job
http://www.vetteweb.com/tech/vemp_08...h/viewall.html
