C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] cup tires up front on stock z06 wheels??
Old 04-08-2014, 01:44 PM
NHRAFreak92
NHRAFreak92's Avatar
Default cup tires up front on stock z06 wheels??
what's up guys im looking into getting Michelin cup tires for my z but I saw that the closest size for the front is a 285/30/18 and I believe our stock size is 275/35/18 what are my options without changing wheels? the rears there is no issue I was planning on running the 345/30/19. If I cant use them then so be it, just wanted to double check before I ordered them!
thank you
Lou
Old 04-08-2014, 01:48 PM
Rupert pupkin
Rupert pupkin's Avatar
285s will be fine up front. You would want that offset anyway. 345s/285s
Old 04-08-2014, 03:55 PM
Dr.Ron
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
thank you
Lou
The 285's are fine. I run them on my track wheels. MPSC ZP's-19/20's on my 2011 Carbon edition Z06.
Ron
Old 04-08-2014, 03:58 PM
LFZ
LFZ's Avatar
The problem with that 285/30-18 cup tire is the diameter...its considerably shorter than the stock size that is called for on our Zs. And running the taller 345/30-19 tire on the rear is bound to throw AH/TC issues. You'd be better off running the 325/30-19 N-spec cups on the rear.
Old 04-08-2014, 06:10 PM
The_Raging_Bull
The_Raging_Bull's Avatar
Ron
Hey Ron,
What size and type cups tires came on your carbon, and what style was the OEM rim??
Old 04-08-2014, 07:35 PM
NHRAFreak92
the only reason i was getting cups was because i was getting the rears for a killer deal, do you think i should just hold off and get the PSS tires in the 275/35/18 and the 345/30-19 in the rear. i run this set up now with run flats up front and 345 NTO5Rs in the rear with no issues, if i run the 285 up front and the 345 in the rear it'll cause some problems?
Old 04-08-2014, 07:39 PM
sickss228
sickss228's Avatar
thank you
Lou
I run this same setup with no problems, except picking up every little pebble on the street once the tires heat up
To cup tires up front on stock z06 wheels??
Quick Reply: [Z06] cup tires up front on stock z06 wheels??
