C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Coilovers/Sway Bar Packages/Shocks
Old 02-22-2014, 12:46 PM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default Coilovers/Sway Bar Packages/Shocks
LG 05-13 C6/C6 ZO6 Corvette ADJUSTABLE GT2 COILOVER
At LG Motorsports our saying is: 'We Race - You Win' and that is why we built the product that we have here. We have always had our G2 Bilstein/Hyperco coil-over shock package, but many of our customers wanted an adjustable shock, so we went to work to make a first-class package just the way I would want it for a race car without welding new mounts in place. This is what we came up with and we did it with no compromises. There are other coil overs out there but they are full of compromises. We did our best to avoid the compromises. We have a spherical bearing set up on our shocks in all mounting locations other than the bottom of the rear shock "Fork" mount. We did this because of the precision that the bearing offers. Precise and smooth operation that does not interfere with the shock function. Spherical bearings are the best option for coil-over mounts. Rubber mounts cause a "Trampoline" effect that must be overcome before the shock can actually work. Rubber also changes the spring rate momentarily until fully compressed. In addition, rubber causes side loads in the shock rod and will eventually damage the shaft. Plastic or Delrin eliminates the "rubber/trampoline" effect, but it introduces new friction that interferes with the operation of the shocks. Forces are forces and the friction involved in a Delrin/plastic mounting system introduces "Hysteresis" losses that interfere with your shock operation.
Reward Points
185 points will be rewarded to you when you buy this item.
Installed Price: $1,995.95
Your Price Delivered Lower US: $1,849.95
We have put together 3 sway bar and shock packages and 2 sway bar packages for the enthusiast who wants to stepup the handling of their Corvette.
1997-2013 Corvette ZO6/Z51/C6 25.4mm(1.0) Rear & 38mm (1 1/2) front Adjustable sway bars
https://www.xplosiveperformance.com/...s-_p_3667.html
On sale: $755.95
1997-2013 Corvette ZO6/Z51/C6 25.4mm(1.0) Rear &35mm (1 3/8) front Adjustable sway bars
https://www.xplosiveperformance.com/...rs_p_2613.html
On sale: $685.00
Package 1
97-13 Corvette Performance Street/HPDE Track Sway Bar's Front & Rear w/Bilstein B8 Sport nonadjustable shocks
PACKAGE INCLUDES
(1) 35 MM Front Tubular Sway Bar, Double Hole Kit
(1) 25.4MM Triple Adjustable Tubular Rear Sway Bar
(4) Adjustable Quiet End Links
(4) Poly Frame Mounting Bushings & Hardware
(2) Bilstein B8 Corvette Front Single NonAdjustable Shocks
(2)Bilstein B8 Corvette Rear Single NonAdjustable Shocks
For the performance-minded driver, Bilstein B8 SP shocks and struts deliver absolute mastery of the road surface. Designed to push a car's suspension to its performance peak, these shocks are well-suited for use with lowered springs, stiffer anti-sway bars, or other suspension upgrades. Realize your cars full potential with these Bilstein B8 SP shocks and struts.
http://www.xplosiveperformance.com/9...s-_p_3640.html
$1089.95
Reward Points109 points will be rewarded to you when you buy this item.
Package 2
97-13 Corvette Performance Street/HPDE Track Sway Bar's Front & Rear w/adjustable shocks
PACKAGE INCLUDES
(2) QA1 Corvette Front Single Adjustable Shocks
(2)QA1 Corvette Rear Single Adjustable Shocks
http://www.xplosiveperformance.com/9...ks_p_3637.html
$1395.95
Reward Points140 points will be rewarded to you when you buy this item.
Package 3
97-13 Corvette Performance Street/HPDE Track Sway Bar's Front & Rear w/Koni adjustable shocks
PACKAGE INCLUDES
(2) Koni 1023 Corvette Front Single Adjustable Shocks
(2)Koni 1024 Corvette Rear Single Adjustable Shocks
Big handling improvements
Reasonable ride quality
External rebound adjustment on most cars
Best KONI shock for all lowering springs
Re-buildable and re-valveable for custom vehicle setups
Yellow exterior finish
Lifetime Warranty
Koni Sport Series Yellow Shocks for a 97-13 Corvette (Coupe/Conv C-5 incl Z06 (exc. Electronic Suspension/MR Suspensions & ZR1)) Features
http://www.xplosiveperformance.com/9...s-_p_3639.html
$1895.95
Reward Points190 points will be rewarded to you when you buy this item.
Old 02-25-2014, 06:05 PM
Former Vendor
St. Jude Donor '13
http://www.xplosiveperformance.com/L...R-_p_2102.html
Reward Points
Sway Bars/Shocks Package 1
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
Sway Bars/Adjustable Shocks Package 2
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
Sway Bar/KONI Adlustable Shock Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
Dramatically Improves Cornering
Lightweight, Durable 35mm(1-3/8") Tubular Steel Front Sway Bar, 20% Stiffer Than Z51 & Z06
Lightweight, Durable 25.4mm (1.0") Adjustable Tubular Steel Rear Sway Bar
Poly Bushings Included Gloss Black Powder Coat Finish
These hollow tube bars measure 35mm (1-3/8" in front and 25.4 (1.0") in the rear and are 20% stiffer than stock in front and are adjustable from +30% to 150% stiffer in the rear. The result is dramatically improved conerning potential, chassis balance and steering response. Besides offering exceptional handling improvements for street driving, these sway bars work extremely well in autocross, road course and open road racing applications. The lightweight hollow sway bars are formed on a CNC machine, powder coated gloss black for durability and includes poly bushings. Adjustable end links are included. Thanks to added adjustability, this new C6 sway bar package reduces body roll, increases vehicle control and adds a new level of driver feedback and control to any late model Corvette, even razor sharp Z06 and Z51 models.
http://www.xplosiveperformance.com/1997-2013-Corvette-ZO6Z51C6-254mm10-Rear-35mm-1-38-front-Adjustable-sway-bars_p_2613.html
Installed Price: $825.49
On sale: $685.00
Koni Sport (Yellow) Shock 97-13 Chevy Corvette Coupe/Conv C5/C5Z06/C6/C6ZO6 (exc. Elect Susp/ZR1) - Front
http://www.xplosiveperformance.com/Koni-Sport-Yellow-Shock-97-13-Chevy-Corvette-CoupeConv-C5C5Z06C6C6ZO6-exc-Elect-SuspZR1--Front-_p_3642.html
Bilstein B8 97-13 Chevrolet Corvette C5/C6 incl ZO6/GS/ZR1 Front
http://www.xplosiveperformance.com/Bilstein-B8-97-13-Chevrolet-Corvette-C5C6-incl-ZO6GSZR1-Front_p_3644.html
Bilstein B8 97-13 Chevrolet Corvette C5/C6 incl ZO6/GS/ZR1 Rear
http://www.xplosiveperformance.com/Bilstein-B8-97-13-Chevrolet-Corvette-C5C6-incl-ZO6GSZR1-Rear_p_3645.html#
Old 03-04-2014, 07:35 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 03-08-2014, 10:53 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 03-12-2014, 08:57 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 03-18-2014, 08:03 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 03-26-2014, 04:33 PM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 04-01-2014, 07:55 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 04-04-2014, 09:23 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 04-16-2014, 10:10 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 04-23-2014, 09:11 AM
Former Vendor
St. Jude Donor '13
Reward Points
PACKAGE INCLUDES
$1089.95
$1389.95 Installed
PACKAGE INCLUDES
$1395.95
$1695.95 Installed
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
$2195.95 Installed
On sale: $685.00
Old 04-23-2014, 09:16 AM
ProEFI
Supremacy 1 car at a time
Support Corvetteforum!
ProEFI's Avatar
OH MY LORD, I'm not lucky @ all just ordered the GT2 and sway bars few weeks ago!! which is double this price F#%$ it .. good luck and nice pricing list!
Old 05-01-2014, 09:54 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Old 05-06-2014, 07:53 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Old 05-10-2014, 10:53 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Old 06-02-2014, 08:37 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Old 06-09-2014, 09:03 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
To Coilovers/Sway Bar Packages/Shocks
Old 06-19-2014, 08:21 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Old 06-24-2014, 09:42 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Old 06-27-2014, 07:39 AM
Former Vendor
St. Jude Donor '13
Reward Points
On sale: $755.95
On sale: $685.00
Package 1
PACKAGE INCLUDES
$1089.95
Package 2
PACKAGE INCLUDES
$1395.95
Package 3
PACKAGE INCLUDES
Lifetime Warranty
$1895.95
Quick Reply: [Z06] Coilovers/Sway Bar Packages/Shocks
