[ZR1] Most powerful blower only ZR1 in the world (Dyno graph inside)
Finished up some extensive porting on Ballbearingturbo's blower today along with an air intake swap.
Before the port it made 798/802.
After..... (Final Pull)
(Same mustang Dyno with corrected numbers)
I think we have a new most powerful blower only ZR1 in the world... Someone correct me if I'm wrong.
Tuned by Lund Racing
Love it! I had the pleasure of watching gkzr1 port the blower every step of the way. I must say it turned out to be a piece of art.
Plus another killer E85 tune by Jon @ Lund Racing, as expected!
What cam is in that car?
I can't see the numbers clearly is it 830rwhp 820rwtq ?
Awesome numbers how much boost? what's the remaining boltons and H/C?
Come on NOT Cool posting these numbers without info
gkzr1 will have to clarify, but this particular dyno is off by 300rpm across the board for some reason. Every point you see in the graph is actually 300rpm higher in real life. Once you add 300rpm, you'll see it should cross at 5250.
I don't have all the details of this build, but the chart says 869rwhp & 823tq @ 17.2psi peak.
Not sure, Tune Time Specs I believe.
"Blower only" as in the blower is the only power adder.
Full list of modifications
Southways 108mm Throttle Body TuneTimePerformance custom cam TuneTimePerformance Ported Heads
Trunion Kit Upgrade
Manley push rods
Titanium dual valve springs
ARP head studs
LPE 2.60 upper
14% lower
LPE Full ported snout (gkzr1)
Full port blower (gkzr1)
ARH jet hot coated 1 7/8" header
ARH catless H pipe
TuneTimePerformance custom 4.5" intake tube Venganence Racing HX and pump
TIKT Hood spacer brackets
ID1300
TuneTimePerformance Flex Fuel
Stock Clutch
Stock Mufflers
Car was dynoed on 19" Nitto Nto5rs radials. At 82% ethanol. About 40 degrees F.
Trunion Kit Upgrade
Manley push rods
ARP head studs
LPE 2.60 upper
14% lower
ARH catless H pipe
ID1300
Stock Clutch
Stock Mufflers
Trunion Kit Upgrade
Manley push rods
ARP head studs
LPE 2.60 upper
14% lower
ARH catless H pipe
ID1300
Stock Clutch
Stock Mufflers
Trunion Kit Upgrade
Manley push rods
ARP head studs
LPE 2.60 upper
14% lower
ARH catless H pipe
ID1300
Stock Clutch
Stock Mufflers
How much timing was in it at 82% ethanol?
Yes you do!
Congrats
