[Z06] Thinking of upgrading axles, any reasons not to?
In my prep to make the car ready for track, I had forgotten about the axles. Being an 06, they've got the skinnier set than the later years. They've never given me a problem before, but I was beginning to wonder if I should just get them replaced while I'm at it.
I'm more of a road course/autocross guy, so I don't really put that much stress on the drivetrain with hard launches, but I may do an occasional drag event and I'd hate to need a tow because I neglected to upgrade the axles.
Besides cost, are there any reasons not to upgrade? Are the C5 Z06 axles still recommended or should I get the 08 axles? Or something else? My research has shown 09+ won't work.
Slightly off topic - Anything else I should do in terms of preventative maintenance? Car is running great with no problems, but want to get ahead of any known weak leaks. I've done the heads (WCCH) and upgraded the oiling system (LPE tank & oil pan baffle) already.
Thanks.
Thanks.
I busted an axle on my 08 at the strip. I changed both to C5 axles and am still running them 5 years later.
Thanks.
Thanks.
Rock auto, search for C5 remanufactured axles. Done!
What I meant was when you attend track events do you tow/trailer it there. If you do I say drive it until it breaks. If you don't you might want to upgrade to the C5 axles.
Thanks. Good point. I'll dig into whether or not this could be a problem for me. Haven't had any cooling issues with the car in the past, but HPDEs are a whole different animal.
This. I run 10s all day launching on drag radials with my c5 axles, never broken one. I shattered enough to figure this out. I've heard the newer improved either 08+ or around there hold up well too. No idea what happened in the early c6 yrs, but they shatter too easily.
Oh, got it. Don't have a truck or trailer. Not to say this isn't a possible option and while there are numerous benefits, I don't think I'd go down this path. At least, not right now.
A-1 CARDONE 601374 (60-1374) CV Half Shaft Assembly, should be about $300 for 2 with shipping.
Part number in bold above for rock auto, all C5 axles are the same. I prefer the C5 to the revised 08s, but thats just my experience with 550 rwhp and drag radials the past 5 yrs on C5ers.
My first two stock axles popped on the street, and I don't suggest waiting for that. These cars are low, and mine lowered 1.5 all around could barely get on a flatbed without damage. It took all kinds of wooden boards to just barely do it.
PLUS, the mess of the grease splooge all under the car, its a nightmare when it happens!
Road racing doesn't seem to kill axles, just drag racing on sticky tires.
Only reason not to upgrade would be time or money. If you have plenty of both I guess go for it.
Cheers, Paul.
Supporting Vendor
Thanks.
Thanks.
After well over 3000 launches and 96K original miles, my right rear axle snapped on the very first pass that day. I had replaced the left one with a C5 Z06 one early last year but it was only because the clamp on the grease boot had let go.
A friend asked me if I planned on upgrading to heavy duty axles but after hearing several horror stories about them and my original one lasting as long as it did, I felt that the best upgrade (albeit only a minor one) was to put a new C5 one on the right side.
They only way to guarantee that an axle will not break at the strip is to never go unless you will spectate. ALL of the mentioned axles can and do break when attempting to launch extremely hard or dumping a clutch that grabs on a sticky track. If your car is apart now or you have down time, then pick up some C5 axles and replace them. Keep the old ones as spares. Since you do not have a trailer, you can bring the tools to the track to change one should it break. (I can give you a list should you need one. It takes less than an hour with hand tools, a jack, 1/2" impact gun, etc.) This is cumbersome but does prevent a tow. You can also launch softer and not try to kill the 60' or cut a light. This will minimize your chances for breakage but not prevent it.
Good luck.
Good luck.
Yeah what a freakin mess when you break one and then getting the car home is a real PITA. And this does not even address the possibility of collateral damage, even something as simply as bending the shaft in a shock, in my case a Penske coilover, got stupidly expensive to fix. I went with the C5 axles and haven't broken since.
Cheers, Paul.
Cheers, Paul.
Looks like the C5s are the way to go.
I just went through this recently when I (finally) broke an axle at the dragstrip on January 5th.
Good luck.
Good luck.
I might just swap these out and keep the old ones as spares for whatever reason. Thanks.
Yep, that crossed my mind as well. It was either replace the axles or buy a new Silverado High Country or Sierra Denali with an enclosed trailer. I had to flip a coin to decide what to do and the axles were the winner. Too bad, we could have had a nice support vehicle for when we go out to the track!
I broke an axle at the track this past season. I debated going with DSS axles and in the end replaced it with a C5 axle. If anything is going to break on a hard launch, better an axle then a trans or diff. (done that too). The axle is cheap, and easy to change, compared to whatever else might break.
I'm on your side, that's why I'm counting on him buying the setup lol. Maybe I will pay for the gas........maybe
One of the best investments if you like to track your car is a hauler and a trailer. It takes the paranoia out of your head and leaves you free to push the car to its limits without holding back because your afraid it might break.
