[Z06] Fuel rails for fast ls7 that do not require an inyector spacer?
I have an ls7 Fast 102 and I need i set of fuel rails that work with small injectors.
All the FAST fuel rails i've been able to see do require the injector spacers. The ones I have were modified to NOT require them, but if I can buy them as is and not having to modify, the better.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,110 Likes
yes, YES ... YES
Anything other that the FAST fuel rails will require spacers with the OEM LS7 injectors. I used the LS2 fuel rails with new 60# Bosch LS2 injectors on my LS7's FAST manifold.
FWIW, I wouldn't run FAST's fuel rails on ANY car I own. There have been many reports of fuel fires due to those POS fuel rails. That's just me though...
Yes... i've hear at the fires.... i had let this "go" as RSI told me their brackets worked for the LS7 with their fuel rails as I have.... it figures, it doesn't... but at least I can modify the brackets/rails in order for the o-ring to not get out.
yes, YES ... YES
Thanks for the info. I am not bothered by the spacers as I have a stock LS2 rail now with the Fast intake, but wanted something that looks better and doesn't leak.
I am going to order new ID850 Injectors, so if I get the LS2 version (which is a little bit taller), can it fit there without the need of spacers..?
