[Z06] The "Out of Spec" Guide Wear Registry
#501
Thank you for the instructions 1972. I've driven it about 500 miles since the swap. I agree with you MTP, especially since Kohle is so thorough to have written in the box "must install lash caps" several times. Given the ease to pull a valve cover, I'll do it when I have some time during this week and post some pictures.
#502
This is what happens after a couple hundred miles without lash caps. Look at the intake valve stems. They're disintegrated...completely pulverized by the rocker arm to the point one fell into a cylinder, and the others weren't that far behind.
https://www.corvetteforum.com/forums...post1596565920
#503
I just pulled my passenger side valve cover off and took video and a picture (below). The lash caps look like they were installed properly on the intake valves. Your thoughts? If there is anything else I should check before putting the cover back on, let me know. 1972: the rocker bolts were at least 22 ft lbs.
#505
That looks a little more difficult to access. Is that strut tower brace stock? I see you also live in Indiana. You should bring that 1972 to the Corvette Indy all Corvette show in August in Carmel. http://www.corvetteindy.com/penske-v...-show-819.html. Thanks again for the help on the covers. It was a pretty easy removal with the instructions you and Jay posted.
#506
I added the strut tower brace. I've replaced the rocker arms on that car, but I think to remove the heads, I drop the engine out.
Thanks for the car show info. Your car looks good-to-go. I know exactly how you felt about needing to know for sure everything was okay. Way too much at stake here.
#507
Here's my results from AHP. Looks like I had 6 intake valves that were out of spec This engine had 30K miles.
Cyl1
Int- 0.10"
Exh- .004"
Cyl3
Int- .035"
Exh- .006"
Cyl5
Int- .006"
Exh- .005"
Cyl7
Int- .014"
Exh- .005"
Cyl2
Int- .020"
Exh- .005"
Cyl4
Int- .006"
Exh- .005"
Cyl6
Int- .011"
Exh- .005"
Cyl8
Int- .009"
Exh- .005"
Cyl1
Int- 0.10"
Exh- .004"
Cyl3
Int- .035"
Exh- .006"
Cyl5
Int- .006"
Exh- .005"
Cyl7
Int- .014"
Exh- .005"
Cyl2
Int- .020"
Exh- .005"
Cyl4
Int- .006"
Exh- .005"
Cyl6
Int- .011"
Exh- .005"
Cyl8
Int- .009"
Exh- .005"
#508
Cyl1
Int- 0.10"
Exh- .004"
Cyl3
Int- .035"
Exh- .006"
Cyl5
Int- .006"
Exh- .005"
Cyl7
Int- .014"
Exh- .005"
Cyl2
Int- .020"
Exh- .005"
Cyl4
Int- .006"
Exh- .005"
Cyl6
Int- .011"
Exh- .005"
Cyl8
Int- .009"
Exh- .005"
Cyl1
Int- 0.10"
Exh- .004"
Cyl3
Int- .035"
Exh- .006"
Cyl5
Int- .006"
Exh- .005"
Cyl7
Int- .014"
Exh- .005"
Cyl2
Int- .020"
Exh- .005"
Cyl4
Int- .006"
Exh- .005"
Cyl6
Int- .011"
Exh- .005"
Cyl8
Int- .009"
Exh- .005"
Welcome to the fraction of one percent club...
Looks like these are "raw" measurements. Good thing you decided to do something about it.
#509
Those appear to be his raw measurements, so anything over .008 would be considered out of spec...which aligns with his comments on 6/8 intakes being over that.
#511
Can you please define raw measurements? All I've ever seen was GM spec of anything over 0.0037" on diametrical difference was out of spec.
#512
We have found that the wiggle test readings are roughly half of the actual mic and bore measurements.
Use this formula:
Wiggle test measurement on dial indicator divided by two then minus .0005". That will get you very close to the actual dial bore and mic measurements.
Use this formula:
#513
Oh. OK. Thanks. So RAW = Wiggle... I knew 0.008 was max on Wiggle. Just had not heard "raw" term. I guess I've been under a rock.
#514
Yup, these were raw measurements. I'm super lucky I decided to take the plunge and just get it fixed. Could've ended up in a very bad situation. I even saw the bad intake valves in person during pickup at AHP and they were definitely in bad shape.
#515
From my 07 Z06, all was quiet, car was dead stock (27K miles) when I bought it, I plan on tracking so this was step one, sent to AHP:
1 int: .0011" 1 exh: .007"
3 int: .008" 3 exh: .006"
5 int: .0085" 5 exh: .006"
7 int: .009 7 exh: .0065"
2 int: .009" 2 exh: .006"
4 int: .009" 4 exh: .007"
6 int: .0011" 6 exh: .007"
8 int: .010" 8 exh: .0065"
Got it milled, went with the moldstar 90 guides, upgraded springs and the 115 cam, So much better to take the car without wondering if today is the day
#516
Ok, so my Z06 failed the wiggle test. Car is at AHP getting fixed, what a great group of guys and Company. Jake has been very helpful.
2012 Z07 with 18090 miles, Bone Stock and has not been raced or tracked since I purchased it almost 3 years ago.
Here are the wiggle test results, any measurement over .008" is considered to be out-of-spec:
1 int .017"
1exh .009"
3 int .018"
3exh .010"
5 int .027"
5exh .013"
7 int .020"
7exh .012"
2 int .0015"
2exh .009"
4 int .0012"
4exh .009"
6 int .0014"
6exh .009"
8 int .0017"
8exh .010"
1 int .017"
1exh .009"
3 int .018"
3exh .010"
5 int .027"
5exh .013"
7 int .020"
7exh .012"
2 int .0015"
2exh .009"
4 int .0012"
4exh .009"
6 int .0014"
6exh .009"
8 int .0017"
8exh .010"
#517
Geez...16/16 with 18K miles. Its in great hands with Kohle and team. Complete build, or just fix the heads?
#518
1 int .017"
1exh .009"
3 int .018"
3exh .010"
5 int .027"
5exh .013"
7 int .020"
7exh .012"
2 int .0015"
2exh .009"
4 int .0012"
4exh .009"
6 int .0014"
6exh .009"
8 int .0017"
8exh .010"
1 int .017"
1exh .009"
3 int .018"
3exh .010"
5 int .027"
5exh .013"
7 int .020"
7exh .012"
2 int .0015"
2exh .009"
4 int .0012"
4exh .009"
6 int .0014"
6exh .009"
8 int .0017"
8exh .010"
For a problem that only affects 1% of LS7s, it's amazing how many of us there are.
