[ZR1] E85 conversion
#41
That's what was provided by dsteck's recommended source so I'm expecting it to be ok. The distance shouldn't be an issue. I checked multiple times with the supplier because I ordered full flow fittings and was guaranteed this will be ok.
#43
Awesome thats great than, like i said the setup looks fantastic.
#44
#45
Thanks! I try to pay attention to detail. The adapter is going to be the cat's meow.
#47
This is probably the best mod you could do to a high strung setup. Better have good injector data however cause things will get a little out of whack on one end of the spectrum or the other with bad injector data.
#48
The cost compared to how much power you can gain makes it hard to ignore, too. FI cars love it.
#50
Sorry to raise an older thread, but I am curious about what people's longer term experiences with E85 have been?
One of the caveats to E85 has been, in my experience, the manifestation of problems in the longer term versus things you notice quickly in the short term. Things like fuel filter degredation, fuel pump failures, etc happen after months if not years, not right away. I think done properly, E85 can be a great fuel, but it has to be thoroughly engineered and tested.
#51
#52
I think that's why a lot more people now do the flex fuel setup and only occasionally run e85, when I do my setup I'm prolly only gonna run e85 when I have some type of race event or something come up.
#53
Ive been running it now for a few months with no problems but as stated it is a flex fuel setup so I switch every tank from 91 to e85. So far so good and WAY better than when I was running 100, but I do miss that smell!
#54
-m
#55
Using gasoline to occasionally pickle the system actually prolongs them significantly. The biggest problem with ethanol is the readiness to absorb water. While I agree that the system should be 100% compatible top to bottom, many factory systems have been surviving for very long periods of time without an issue while running true flex fuel setups. A diet of nothing but McDonald's cheese burgers will kill you, but mixing it up with healthy food will balance you out.
#56
#58
#59
Thanks for joining this thread. Would you be confident enough to add actual figures to your claims?
How often do you have to "occasionally" pickle your fuel system with traditional fuel?
How long does this pickling, if done as necessary, prolong the reliability of the fuel system?
How many factory systems have been surviving?
How long have they survived?
I appreciate your rhetoric, but without some actual firm data it is hard to speculate what is truly possible. If you are in the business of selling systems to make our cars more E85 compatible, this kind of data could go a long way into getting people like myself and others on board with it rather than sticking to the sidelines because of speculative hesitancy.
#60
asking someone for Data with so many different factors isn't really realistic imo. If there is that much concern then the entire fuel system should be replaced with something ethanol capable.
