[Z06] Which engine oil,,royal purple or mobil1 ???
I have c6 z06 2008,,STOCK,, DAILY DRIVEN,,NO RACE TRACKS NO DRAG ..
MY NEXT OIL CHANGE WILL BE NEXT MONTH ???
SO IM STUCK BETWEEN ROYAL PURPLE AND MOBIL 1???
IV ALWAYS USED MOBIL 1 SINCE I HAD THE CAR AND TO MAKE SURE I DONT MIND USE IT AGAIN,,BUT I HEARD GOOD NEWS ABOUT ROYAL PURPLE>THEY SAY ITS BETTER FOR PERFOMANCE??
SO I NEED YOUR OPINIONS GUYS REGARDING THESE BRANDS????
Royal Purple actually performs fairly poorly. If you want a top performing oil that will not break the bank, go with Pennzoil Ultra.
http://speedtalk.com/forum/viewtopic...f7a2aba9203c4b
wooow thats crazy
RP known for building oil for nascar and high perfomance car ,,,its not possible to wear out easily.....
i live in bahrain ( middle east) ,,we have dealers for RP and mobil1 and some other brands...
but redline none of them,,
if i order oil i will pay more $$$$$$$ for international shipping
so thats why i am between RP AND MOBIL 1 because its easy to get.
Joe Gibbs Racing Oil is the choice of MANY top engine builders. They see more wear from racing than most other people do. I trust my engine builder and want to do pretty much everything he recommends. Joe Gibbs is what he tells me I should run. So I do!!
Joe Gibbs is good. I run amsoil. Out of your two choices I would just do M1 over RP.
Never had good luck with RP. Seen way too many turbos fail when using RP oil. Seemed to be a common thing getting turbos back with bad bearings, and for a time most of them were using RP oil. Just never liked it or had good experience with it. M1 is ok if you get the high mileage or euro blend.
Overall I run amsoil now and wouldn't switch back.
Pennzoil Ultra 5W-30... designed by Shell and Pennzoil used in all F1 cars , Ferrari's and Vipers and SRT race vipers. Read the article yourself.. really good info.
http://540ratblog.wordpress.com
When choosing an oil filter us the NAPA Platinum. I'l find the test a CTS-V owner did with all the filters and it out performed all of them and is only 8 bucks.
