[ZR1] LMR Reaper ZR1 makes 811rwhp on E85!
Supporting Vendor
Just finished this Reaper Package ZR1 with a Flex Fuel conversion and needless to say the results speak for themselves! We tuned the car first on 93 octane and it ended up making 737rwhp and then we added E85 to the tank, made necessary tuning adjustments and it made 811rwhp!! A gain of over 70rwhp!
Supporting Vendor
C6Z American Racing X-pipe with high flow cats
02 Extensions
NGK Spark Plugs(Iridium)
MSD 8.5m spark plug wires
Custom Heat Exchanger
Heat Exchanger water pump with connector
C6 ZR1 High Flow Supercharger Air Intake Snout
C6 ZR1 LS9 2.60 11 Rib 10 Bolt Pulley
ZR1 Corvette High Flow Air Intake Kit
100 mm Diameter Idler Pulley Kit
C6 ZR1 CORVETTE OVERDRIVE HARMONIC BALANCER 2009-2011
160 degree thermostat
LS3 Comp Cam Kit, Comp custom grind cam shaft, comp Double valve spring kit good for .675 lift, Titanium Retainers(custom for ZR1), Spring Seats, Valve seals, and comp chromoly pushrods
Water pump gaskets, Oil pump inlet tube, front cover, crankshaft front seal
LS9 Crank Bolt
LMR custom CNC'd LS9 cylinder heads
Katech Head Stud Kit
MLS Head Gaskets
125# injectors
LMR custom Flex fuel conversion
Spec Twin Disk Clutch
LMR custom dyno tuning
The Consigliere
Received 5,458 Likes
Stout power.
What's the driveability/behaviour like with the Spec clutch?
Very nice numbers. That's gonna put a big smile on someone's face!
Supporting Vendor
Price for the clutch was $1649.00
To switch to E85 all we changed was injectors then wired a custom Flex Fuel sensor into the stock ECU and enabled it in the computer.
Stock fuel pump
It is a little aggressive to be honest, But the guy plans on racing the car so it was justified.
Ill have to ask the tuner what the timing and boost was at.
Stock fuel pump
Stock fuel pump
Supporting Vendor
Supporting Vendor
