[ZR1] High Mileage ZR1's - who has the most?
Non stop wheel vibration. Gm refuses to replace rotors. Have rebalanced tires and replaced wheel bearing. Still vibrates. Have contacted gm several times regarding this.
Both catalytic converters replaced.
Bad reverse gear retaining pin.
Reprogram radio.
Replace battery.
Replace interior carpet due to shrinkage twice.
Interior door switch loose.
Emergency brake would not release properly.
Ac musty smell, fixed ac drain.
Defective tire pressure sensor.
I think there is more, although I need to look up to find the rest.
Reprogram radio.
Replace battery.
Sorry to read about all the issues you have been having! Do you have a case number with Customer Care? I would like to review your case. Will you please private message me that number or your VIN please? Thanks,
Kelly J.
Chevrolet Customer Care
Nanook how about waxing that car...........lol
The Consigliere
Received 5,458 Likes
St. Jude Donor '12-'13
#33
lifeislikeaboxofchocolats
Okay guys... i can't take this abuse any longer..I'm going out to detail the exhaust pipes ...
#34
Joe
#36
#40
If you are asking this question in reference to the longevity of the motor then I would ask who regularly tracks their car and has the highest mileage. Mileage is irrelevant in the sense of revolutions the motor has seen. I can take two identical cars with 50k miles and one that was putted around in at 1500rpms on the highway vs one that was tracked and lived its life at 5k rpms. The wear difference would be huge even though they have the same mileage.
My 2011 SuperSonic ZR1 has 10,000 miles.
