[Z06] Valve Bounce: Failing Motors ???
So unfortunately the Katech thread was closed at Jason's request. I didn't see the posts any more cantankerous than normal. I should probably be happy it was closed as I was starting to get bashed pretty good
Anyways, regardless of what some may think I actually want more information. My focus is on stock cam setups only. Thats what I have and will keep. It provides more power than necessary for my track addiction.
I have a lot at stake here. I put 500 daily driver miles on every week (now have 132,500K miles) and track the car at least once a month. I have blown up a motor going over 120MPH and really don't want to do that again.
But my motor and several others I have seen blow on the track all had stock setups. And the forum is full of plenty of other completely stock motors that have and continue to fail on and off the track.
So my question is simple: How many if any of these failures is do to valve bounce. Is it possible that valve bounce is irrelevant up to and maybe beyond the Comp Cam safety limit of 0.02"
Is it reasonable to assume that SS valves are going to be much more resistant to bounce that hollow ones. It seems likely.
I will not switch out my SS valves. I saw a broken hollow valve in person as well as many pictures on the forum so SS is staying. Now I would be open to changing springs to PSI or anything else if they are more likely to prevent a blown motor than the duals.
DH (DDS)
DH (DDS)
Received 8,958 Likes
DH,
Are you talking about floating the valves?
Bill
Bill
Bill
I'm talking about the VALVE BOUNCE that was analysed by the Katech Spintron testing.
Katech is stating that all of us guys with stock cams, ss ex valves and dual springs are 0.001" over their 0.015 safety limit. Our motors are therefore at risk. I am trying too see if there is any real world correlation.
Maybe bounce is part of the reason stock valves are failing. And maybe even though SS valves have more bounce they are so much stronger that they will not fail from this issue.
I know between you and me we have seen a lot of stock motors blow up. Ever hear of one failing from valve bounce??
DH
DH
Could someone please explain what the danger is with valve bounce? (Honest question). Are the valves exposed to increased forces during bounce which may lead to breakage? And/or are there other issues such as the exhaust gas traveling backwards through the intake valve into the intake manifold?
DH (DDS)
DH (DDS)
When someone is prepared to supply highly technical and relevant valuable information to a forum in an attempt to help people with such highly technical and relevant issues, I would suggest a bit of decency be shown to the supplier of the information regardless of irrelevant personal issues.
Anyhow the bickering has now removed one of the only sources of such useful information so that is truly a shame. All the repeated dredging of "he said she said" stuff is sickening when what is really needed is co operation and respect. Not that difficult surely?
Howie valve bounce is not an issue with your setup or anyone else for that matter using the spring Richard uses or any good duel springs, ss valve have been used for a long time.in hotrods for over 50 years. you ask any vendor that besides k an you will get the same answer. the issue with valves dropping is heat related as richard has told you I'm sure
Bill
DH
DH
As I have said before......
Since there is a difference in opinion between the experts, it is up to the individual to pick the expert(s) he wants to trust.
DH
In normal operation where valve float is non-existent, a valve will experience 20,000 to 25,000 lbs of applied stress. However, when valves bounce on the seat the stress immediately soars to 40,000 to 60,000 lbs. Manley exhaust valves ( at 40,000 psi and 1400°F ) ran to 100,000,000 ( one hundred million ) cycles while competitors’ offerings failed at 100,000 cycles. That’s 1000 times better fatigue life.
http://www.manleyperformance.com/pdf...alves-3-50.pdf
Problem is, on the Spintron tests w/the stock cam the Rev valve hit .011 bounce at 7000 RPM while the OEM valve was at .007 at that particular RPM, which happens to be peak shifting RPM unless one was short shifting. Depending on how the stresses mentioned in the Manley article break down with regards to measured bounce (data unavailable), that difference between .007 and .011 bounce could be 7,000 lbs of force. Or 11,000 lbs. Maybe the valvetrain can handle that extra 7K lbs or 11K lbs. Or maybe not. I'm sure that some safety factor is build into the design, but the question is how much.
I also wonder if some of the cam lobe and lifter wheel damage we see is a result of valvetrain instability (loft, float, or bounce), even in a stock engine (recall those mangled spring seats on Z06_505's heads).
I am doing my best to understand what he means then. With my setup he says I must lower my redline RPM. If I don't then you tell me what he is saying will happen ???????????
DH
Otherwise you're just hoping that you chose the right guru, and you would really have no basis to claim that the other guru(s) are wrong.
I assume that since everything is in intimate contact, not only is such stress on the valve, but it is also on the rest of the valvetrain... shims, retainers, locks, rockers, pushrods, lifters, and cam lobe. It should be obvious that zero bounce is the goal, but based on testing it is also obvious that zero cannot be obtained. Therefore minimizing bounce should be the goal. And no, a .001 difference surely can't matter much. However, the RPM should be factored into the equation, not just the gross difference in bounce (in this case, .001).
Problem is, on the Spintron tests w/the stock cam the Rev valve hit .012 bounce at 6900 RPM while the OEM valve was at .006, or half that, at that particular RPM, which happens to be routine shifting RPM on a road course unless one was short shifting. Depending on how the stresses mentioned in the Manley article break down with regards to measured bounce (data unavailable), that difference between .006 and .012 bounce could be 5,000 lbs of force. Or 15,000 lbs. Maybe the valvetrain can handle that extra 5K lbs or 15K lbs. Or maybe not. I'm sure that some safety factor is build into the design, but the question is how much.
The stock bounce may be incidental to the valve train components GM selected for reasons unrelated to bounce (RPM, whatever). Isn't it possible that GM would have been fine with the bounce seen with the dual springs/SS valve?
Is it possible that even the low bounce seen in the stock setup is still too much for the hollow valves but not a problem for the SS valves. And thats why we see so many hollow valve failures??
Thats why I am asking if anyone knows of a motor failure due to bounce??
DH
I am sure that less bounce is good, and more bounce is bad. How good or bad is a question for the people like Manley and GM.
I don't know of one but surely it happens. Otherwise no one would be concerned about it.
Howie Richard would not steer anyone wrong . Your motor is fine and will be fine . Enjoy the car track or street . His set up and work is proven .
And bounce would not explain the worn valve guide issue, which is the most likely reason for the exhaust valve failures.
Edit: It's an interesting technical discussion but bottom line, on a stock cam it doesn't look to be a major issue one way or the other. I might short shift a bit, say 6800, just for a little cushion but otherwise the bounce plot doesn't look very extreme compared to the OEM plot.
Sorry if you are not in the mood. Maybe you shouldn't participate in this thread if its too exasperating for you. I have legitimate questions that another member is already inquiring about too.
DH
DH
And that, I presume is why you are inquiring about that which you are inquiring about.
From all of the discussion, as well as the GM High Tech Performance article, the issue of valve bounce, causing potential failure, is apparently not something that people running the setups that have "passed" the Spintron test, should much worry about.
It is those running setups which have not "passed" the Spintron test who are at risk of bad things happening due to valve bounce.
But apparently, not many of those have been described in here as having actually failed
You know, I have read that article now several times, and several things in it stand out to me, a few of which I inquired about earlier.
But one of the other things in it, that stand out to me in the text of that article, aside from the bounce plots, was the statement:
"Conclusion and Discussion...
These rules of thumb all have an exception in some situations and configurations and are generalized to what we most often see in our valvetrain testing."
Read more: http://www.gmhightechperformance.com...#ixzz2ZeFSv2iu
About the only one that I can think of which some might be inclined to attribute to valve bounce, would be Madsen's failure.
Of course there is no actual proof that this is what happened in his car.
But his is one of two SS exhaust valve failures reported in here, the other being that of 1stZ who failed a SS valve, after first failing a stock exhaust valve, so ultimately, he lost two motors.
In response to several inquiry are as follows:
First Motor:
1. First and foremost: IMO, engines just like most parts in my car are consumables. That said, I feel that I got LOT of used from both of my motor (really beat on in the track & even on street).
2. First failure was on the stock hollow sodium field exhaust valve. From Summer of '06 to fall of '08. ~40 track days (RR) & total of 17,xxx miles. First 14k miles, car only had KB CAI & tune. I then added the cam & headers after 14k miles & then lost the motor at 17,xxx miles.
3. It happened in the track going from 2nd to 3rd gear. Not a mis-shift at all. It tore up the stock pistons & hairline crack on block sleeve. Crank & conn rods were fine. (exhaust valve#2)
2nd motor (build objective was more durable rather than hp/tq. Dyno'd at 550 hp 500 tq. Forged bottom plus all the usual goodies in the heads like crowler rockers, etc...
1. 20k miles on the motor and 18 track days.
2. It happened with me going ~150+ mph & was waiting for close to redline before shifting but before I could shift to 5th, it blew.
3. This time was on stainless steel exhaust valve. Tore up the block, conn rod & piston (exhaust valve #2). Not sure if its a coincidence re: exhaust valve #2 braking.
To those who were suggesting driver error, yes. That is a possibility. But that did not happened to me. At any rate, I believe we just have to take extra precaution. As i mentioned before, I was already planning on tearing it down at 15k miles to check & refresh but delayed it cuz of lack of funds. There's no way around it guys. You play you pay! I enjoyed every mile! Was disappointed that I lost the motor sure. But just have to work, save $ for the next motor.
First Motor:
As far as all of the STOCK exhaust valve failures in here, in STOCK cars, the reported causes have ranged from supposed "broken valve springs", to heads of valves snapping off, possibly due to "worn valve guides", to unknown.
With regard to "cam only" setups which have failed stock exhaust valves in here, again, I cannot recall any of them being attributed to valve bounce.
Also of importance, it has been hypothesized, that some of the failures reported as valve failures, may actually have been piston failures.
You know, one would think, that after several years of these setups being around, and of course in your own environment where several of your track mates have SS valve setups just like yours, that if the worst were assured with these setups, that we would have been hearing about more failures in these SS valve configurations than we have.
But that has not been the case.
BTW, and on a side note, does anyone know, if the stock LS2 and LS3 valve trains were Spintron tested?
The reason I ask, is because they both use solid stemmed stainless steel exhaust valves.
