[Z06] Valve Bounce: Failing Motors ???
#221
hoefi theorized that a Spintron is run like an inertia dyno, as best I understood his post. A quick zoom up the RPM scale and all measurements are quickly recorded. That does not seem to be correct.
#222
What do you think his answer was?
Here's what I think his answer was: A sodium valve is not necessary in the LS7. I think you could go so far as say that his position is that the sodium valve is a mistake.
Clearly the LS7 engineers disagreed with him on the first part, and probably on the mistake part too (since they continue to use sodium valves in high performance engines). You simply have to decide who knows more about the LS7 engine and the LS/LT platforms in general, with respect to the combustion and valvetrain details and goals... the people that designed it, or hoefi.
#223
Very good thread/discussion by the way. Keep it coming. Were all stubborn to what we think the problem is but either way the issue needs to be found....
#224
You have to keep the bean counters in mind on these valves also. It's a cheap light valve that "supposedly" is the ticket for valve weight stability and heat disapation, but does it really work well in this combo for longevity!?
#225
and I would say GM over hoefi...
#227
The lack of data before the spintron could also be directed at how many cars Katech has modded with OEM valves or lighter than OEM without issue. That is however the principal argument for SS valves currently as well.
#230
Otherwise, I see your point -- in order to save money, the bean counters insisted on a valve that costs more than a simple hollow valve which in turn costs more than a simple solid valve. Well done
#231
I agree with that as well, but its all we got. I'll take data over lack of data however small the audience.
It's an interesting conundrum as well...katech certainly being an authority and expert on the LS7 , trusts the work and expertise of WCCH, although they don't recommend the same when it comes to the valves..but just the mere fact a company like Katech would entrust their head work with WCCH in turns makes me comfortable enough following WCCH recommend of the SS valves...even though katech says stick with OEM
and honestly , even though I put them in my heads (SS valves), I would agree I really don;t think the OEM valves are the problem, I think its a machining issue with the guides. ..and the different rocker ratio the LS7 has vs the other LSx motors that have more similar set ups to each other. This amplifies the problem with bad guides.
#232
http://speedtalk.com/forum/viewtopic...29538&start=45
Any vendor in here can, and very likely has had a failure, or will have one.
#234
Your point is valid. But so is the fact that no body including GM is perfect. Mistakes can be made, have been and will be. It is beyond disputing that these motors fail prematurely and too often. It stands to reason that there are likely measures that can be taken to combat this fact. We can argue if one approach or another makes sense or not. But the argument that GM is GOD will not fly in my book.
DH
#235
I wonder if anyone ever offered up any clarification as to what happened to this one. Looks like broken valves to me.
I never heard about this site.
Seems like some fellas with a lot of experience.
Why is it every where you turn people are putting SS valves in?
Did I read that right? Katech has had motors fail too?? I thought they had an unblemished record?? Maybe this guy is making it up
DH
#236
#237
Thanks for the link Ricky
Did I read that right? Katech has had A motor fail too?? I thought they had an unblemished record?? Maybe this guy is making it up
DH
DH
It's no secret that I went the Katech route with my heads and it's also no secret that you went the WCCH route. All that I know is that if I ever read a post about a head done by WCCH with SS valves failing I'm not going to be the one coming on here putting up a sarcastic post saying "Oh wow, look a WCCH head with SS valves failed did I read that right???" etc. etc. Why? Because I like to think of my self as a mature adult that is above that and mainly because I'd feel like a giant douche bag finding personal satisfaction in someone else suffering. Personally I hope that all of the "so called" fixes to the valve issue that have been put out work so that all of us only have to go through this once in our life time! (something that I think we can all agree on we should not have to be dealing with in the first place!)
In any case though to avoid any confusion I took the liberty of correcting an error in your post above in red. I would not gloat too much though as the guy that posted the picture on that thread stated it was an Air Attack head which means that it was used in a boosted application in which heat often plays a major factor in a valve failures. So first of all we have no idea of how much boost the guy was running when the engine failed. Secondly we also have no idea what configuration the engine was being run in. If it was super charged Katech recommends their Ti/Mo intake and stock exhaust valves , if turbo charged they recommend their Ti/Mo intake and Iconel exhaust valves.
So....there can potentially be more factors to the story than just the type of valve used. In any case let's all please stop making these posts and/or threads into some veiled attempt to prove someone wrong or bash a company and turn it into a place to exchange information and discuss things in a pleasant manner as this thread was supposedly started (by you) to do.
#238
Pretty strange claim. If true, then why do they put water jackets in the head?
Let me draw a picture so that it might be more clear. Say you have two engines:
Engine A has sodium exhaust valves and oil squirters. At max power the exhaust valve face operates at 1000°F and the piston crown operates at 500°F.
Engine B is exactly the same except it has solid exhaust valves and no oil squirters. At max power the exhaust valve face operates at 1300°F and the piston crown operates at 700°F.
Which engine:Engine B is exactly the same except it has solid exhaust valves and no oil squirters. At max power the exhaust valve face operates at 1300°F and the piston crown operates at 700°F.
1. Will last longer?
2. Is less likely to experience pre-ignition and/or detonation?
3. Can tolerate the most additional timing (power), albeit at the expense of #1 and #2?
4. Can tolerate the most additional compression (power), albeit at the expense of #1 and #2?
BTW,if clarification is needed, my posts have been focusing on the temperature of the combustion chamber (which technically includes the piston crown), not the temperature of the combustion gases. Although the former is rather dependent on the latter, I don't think they are considered the same thing.2. Is less likely to experience pre-ignition and/or detonation?
Reread my post on thermo dynamics (more than once if required). I was VERY CLEAR on what I wrote.
Bottom line is, if you feel what I wrote is wrong, then I am sorry, you have lots of studying to catch up. Stay off the keyboard for a few weeks and borrow some books from the library. I am serious.
#239
No need to guess. Here are the answers:
1) IMHO, a sodium valve is not necessary in the LS7. Lots of LS7 running with non-sodium valves. Including Katech's turbo LS7 with the solid Inconel valve. Any report on burnt valves yet??? Not even one?
2) I wouldn't say the sodium valve is a mistake. I think it's a poor choice. I also think it's poorly executed in terms of final design and quality control.
The only real mistake is GM's refusal to move into the new era and start building multi-valve OHC engines. In terms of lighter is better, what better way to lower the weight than actually throwing some drivetrain parts away. Yes, hollow is lighter than solid, and titanium is lighter than hollow, but "nothing" is the lightest.
#240
DH
DH
