[Z06] Raod Rash Fix
Raod Rash Fix
The infamous road rash on the Z's where the back air intake scoop is. I have a black Z and of course it looks like salt N pepper!
Does anyone have any successful results fixing this or making it look better without having to go to a body shop? I've heard of some product that you actually wipe or run it in with your finger then wipe it but not sure.
Any help would be appreciated.
I've had the same problem and have used some of the black wax products out there with some success. Just be sure to wash the area with Dawn dish soap first to get the old wax out of the affected spots
A couple of suggestions.
1. touch up paint applied with the end of a tooth pick. Clean the rock chips with some denautured alcohol or paint prep on a Q tip. I use simple lighter fluid you can buy at your local CVS. It is essentially Naptha. Dip the end of the tooth pic in the paint and take a very small amount of paint on tip. Barely touch the tip to the rock chip and move to the next one. Allow to thoroughly dry before waxing.
2. Buy a black Shaprie and touch up chip marks. This works amazingly well.
Good luck with it.
Good luck with it.
I tackled this exact problem on my brother's 07 Z a couple of years ago.
Scroll to post #18 on this thread. I describe how I repaired the road rash without a professional respray.
http://forums.corvetteforum.com/c6-z...he-detail.html
Also see post #23 and #33 for more info on what I did.
Has anybody tried airbrushing? I think I'm doing that over the winter. Mine have looked horrible for a while.
Awesome job
Very nice job, I'm assuming you got the local Auto Paint Store to put the GM spec blue paint in the spray can, did you also re spray the clear and use the clear that the auto paint store mixed and put in another can?
Did you use ultra fine 2000/3000 grit sand paper to remove the paint or did you go with a rubbing compound?
I like your avatar. My brother just left VRC-30 a couple months ago. Already misses San Diego.
Road rash
I own a yellow 06 ZO6 and with 68k on the clock there is some road rash in the areas you described, my fix is easy, I buy 1/2 wide electrical yellow tape and I tape the edges with the tape. The color matches about 95% but it fades so then I peel off the old tape and put a new piece on which is exactly what I did today. I will be glad to email you a picture of the area affected if you give me your email address.
Regards
Reiner Studenroth
Regards
Reiner Studenroth
Received 8,997 Likes
If you look carefully you will see the road rash is also on the lower doors, rockers and most of the panel that includes the back brake vent. Most of the time the salt and pepper look comes from the thousands of edges of the chipped clear coat that reflect light differently than smooth clear coat. The color coat is usually not chipped. If you inspect the area closely after running water over it and the salt and pepper look disappears then you can use a non-residue wax like Turtle Wax Ice to hide the damage. The result will last for a while and it is easy to retreat the area when it starts to show again. Other than that you will need to get a professional to sand and paint the area and then get some low hanging mud guards to keep the stones from being thrown from the front tires. Apsis style guards are better than none but the ones I have still don't hang low enough and I still get damage in that area despite adding ZR1 side skirts. I just keep hiding the damage by throwing on the ICE.
Bill
Bill
