C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] camber issue with coilovers
Old 06-16-2013, 08:33 PM
shlagher
shlagher's Avatar
Default camber issue with coilovers
I bought an 06 z last week with pfadt coilovers the back end is lowered down to where the tires are right below the fender, the inside of the tires are wearing more so than the outside, is this an issue that an alignment shop can correct or do I need some sort of camber kit to adjust this? I hate o raise the car up any because it looks good the way it is sitting.
Sean
Old 06-16-2013, 08:54 PM
mariofromnewyork
Late Model Domestics
Support Corvetteforum!
mariofromnewyork's Avatar
The camber is most likely set like that so the tire can tuck in the fender with out rubbing. If you take camber out it will most likely rub if you dont raise it up.
You ever see those import cars? Crazy camber and stretched tires over the rim.
Old 06-16-2013, 09:09 PM
RoHo
RoHo's Avatar
The coil overs are adjustable, try raising the back end a 1/2 inch and check your clearance and you should be good to go.
To camber issue with coilovers
Quick Reply: [Z06] camber issue with coilovers
