[Z06] Busted PRC .675 Double Valve Spring after 10k miles
#42
After pulling all the rockers I discovered that I get to pull the heads. 5 of 8 Titanium intake vales are worn down nearly to the keepers. Mind you, these heads were set up at TEXAS SPEED for the cam (mild .613/.623 lift) that was specd by them with their push rods (7.775), and new gm lifters. I did not do the work, I purchased the car with this setup. The car has 19k on the clock, from what im told around 6-7k on the heads.
I would like to know what causes this wear?
#44
#45
I also read that roller tip rockets should be used with hardened tip Ti valves. It's what Ferrea also states if using their Hardened Ti valves.
Couple of threads out there with broken tips. Good luck
#46
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,111 Likes
When were the heads bought? Texas speed seemed to be having problems with their hardened tip Ti intakes after sometime in 2013 when the switched to Trick valves. I believe they've now switched to valves designed for lash caps. I'm running their Manley Ti hardened tip Ti intakes. I'm not aware of and problems with Manley valves. At my 10K mile wiggle test all was normal. They used Manley prior to trick. I bought mine in September of 2012.
#47
Texas speed is not taking responsibility, first they said the vales needed lash caps (I knew they didnt) so I asked why the good intake valves have the same stem height from the locks as the exhaust valves - they then responded that my valves were made by Trick Titanium and to contact Trick regarding my issue.
Trick basically replied that Valves do not break by themselves (thanks for the enlightenment, I have guns that dont shoot by themselves either) and that they were not set up correctly by TX speed.
Long story short by what Ive learned, if you have PRC heads, #1 swap the springs for BTR or other high quality type #2 if you have Ti intake valves and they dont use lash caps, expect to replace a set of intake valves.
#48
Time for a lawyer in my opinion, that will quickly change their tune.
#49
Any signs? (like getting louder) I too have PRC 265's but opted for their 700 lift springs (no longer an option on their site) with Ti Intake/SS exhaust. About 4000 miles so far and runs like day one install.
#50
So BT- is there a direct replacement dual spring for the PRC 265 head that will handle 650-660 lift ?? I have no issues but may buy a set just in case. thanks
#51
I also have the PRC265 heads(purchased July 2013) but my Ti intakes use the lash caps and I have a little over 12,000 miles on them. I am running a stock cam.
#52
You have the better setup, same as they use now (oem valves and lash caps) and same as I installed. Hopefully this will last.
#53
No audible signs, Ran great up until it broke. Fortunately the double spring saved any piston interference. The worn stems did make a bit of noise but nothing that was remarkably loud. The vengence guys even said it was just a loud motor, nobody could know without opening it up.
I purchased this kit : http://www.briantooleyracing.com/660...ers-sk001.html
this is the descriptor - " .660" Lift Dual Spring Kit for LS engines using stock rocker arms. Includes dual polished springs, matching titanium retainers, your choice of locators for stock or bronze guides, locks and seals.
Spring specs are 155 lbs @ 1.780", 380 lbs @ 1.180", 400 lbs @ 1.130, coil bind @ 1.070" This is a drop in spring kit for all 15 degree LS heads including LS1 LS2 LS3 LS4 LS6 L76 L92 L99 LQ4 LQ9 L33 LSA, etc, this kit will also fit LS7 heads with approximately .045" of spring shim, see items SS015 and SS030.
#54
^^ Thanks, just to confirm, good for the PRC head? (need locators for bronze guides which is an option but I'm thinking installed spring height of the PRC head vs a stock ls7 head? I supposed lots of checking but shims are mentioned.
With all the research Ive done over the last few days Ive learned that there are only a few companies that actually make springs, with comp cams being one of them. Id assume since Texas Speed prides themselves as being one of the largest comp distributors that they indeed would have comp make their springs as well.
#55
sent you a pm
sent you a pm
#56
Before blaming the springs, make sure they were installed correctly to begin with. IE: Install height, distance from coil bind. PAC and PSI are my two go to companies for springs. Ferrea has some good springs too. I am currently using Comp springs, and they are working quite well to date (6K miles): COMP 26926TI-KIT They were the only spring I could find with the rate and loads I needed for .670 lift.
O.D. Outer Spring: 1.320''
I.D. Inner Spring: .654''
Spring Rate: 505 lbs/in
Seat Load: 129 lbs @ 1.835''
Open Load: 470 lbs @ 1.160''
Coil Bind: 1.100''
I had them checked last fall, to determine whether or not is was time for a spring swap, but rate/pressures were right on the money.
Coil Bind: 1.100''
#57
Premium Supporting Vendor
Don't worry give us a yell & we will get you lined out. The valves are top of the line Trick Titanium valves. They will help if something is going on with them.
Don't worry about the spring we will swap you over to the updated version of the .675" spring. It has slightly less spring pressure, but is super reliable.
#58
18k miles on my prc 285 with .650 lift springs, zero issues. TSP is a top notch place.
#59
#60
Im sorry man but I have to call you out with a big fat BS on that.
I called Tx Speed and was basically told tough ****!
I was told to call Trick, and they gave me the same runaround that you guys did.
In the end, the heads were purchased from you guys, not Trick. Your company should have stood behind the flaw vs telling me I could purchase a new set of springs from TSP for full retail.
You guys are more than welcome to reimburse me for the new springs and valves that I had to purchase on my dime to repair an inferior product. $299 for springs and $800 for valves..
I wont hold my breath waiting at the mailbox.
I talked to them twice, looks like I'll look into going Diff route.
