[Z06] Carbotech Performance Brakes
Supporting Vendor
St. Jude Donor '11,'13
All new XP24 compound for serious racers or track days. I will be happy to answer questions or place orders.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
The goal was to decrease the wear rate yet maintain the high friction and fade resistance of the other high end XP race compounds.
Along the way these pads:
-Have the most linear friction curve we have seen.
-Are lighter than the other compounds.
-Last longer on track.
Supporting Vendor
We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application. Contact info is below if you need some help or would like to order a set. Orders place direct through me receive 5% forum discount.
Supporting Vendor
Carbotech Performance Brakes™, the world leader in Ceramic friction materials™. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic™ compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry.
#33
Supporting Vendor
From street use to the higher performance demands of track days, we'll help you achieve better brake modulation, torque and fade resistance. High-tech construction means better stopping power and a higher level of driver confidence every time you get behind the wheel.
#34
Supporting Vendor
Carbotech brakes utilize a ceramic and metallic construction in a range of compounds that out-perform competitive brakes. Carbotech brakes are made from compounds that offer higher initial bite, torque and fade resistance—providing consistent brake modulation and performance over a wide range of operating temperatures.
#38
To anyone considering buying brake pads from Adam, I want to tell you that I have bought 2 sets from him and his advice, attention to detail, and hard work is well beyond what I normally experience from other venders.
THANKS AGAIN for all your help Adam! We are lucky to have you as a part of this Forum!!!
#39
Supporting Vendor
