[Z06] resetting TPMS-
Cruising
Working Range for the pressure monitors
Does anyone know the proper range within which the tire pressure wil not set off the dashboard warning light? I have a new 2013 C6, and every time I drive it, the tire pressure warning light comes on. I have lowered the cold temp pressure from the recommended 30 psi to 29 psi, but after about 15 to 20 minutes of highway driving, the tire pressures rise to above 32 psi and then show xxx with the dashboard warning light lighting up.
Do I have defective sensors? Can the pressure range be broadened?
Wil Cooksey #256
with Dave!!
I don't think you have a problem with pressures - the pressures only give alerts at the pressures Dave mentions.
Do ALL tire pressures indicate "xx psi" or just one of them??
Normally "xx psi" indicates the TPMS isn't receiving a sensor - it either has a bad battery or is otherwise inop, or it's not properly programmed into the TPMS computer memory.
The fact that when you drive the pressure increases indicates that the sensors are programmed in and as the tires heat up the pressure rises.
I would suspect that a sensor battery must be bad.
These are the stock wheels, right - you haven't swapped on a different set of wheels with different sensors, have you??
Bob
Bob
Cruising
Bob,
The tires are those that came with the car. I bought the car at the beginning of January (a little over two months ago). It happens with all 4 tires. I don't know if it's related, but the car has difficulty finding and maintaining GPS contact too.
Guess I'll have to take the car in for service.
Thanks.
Thanks.
As Bob already knows, the air we breeth is already 80% Nitrogen, so really don't see the big deal either, other than moisture on a humid day. Also, don't see the big fuss on the TPMS system, as think it's pretty good myself. Sure you can put the sensors in a tube to fool the car computer, but won't help with a trashed tire, because you had no warning. Personally I just roll with it, and put sensors in all my wheels.
#35
Well I drove my car today-Felt great!First time this Year!
I drove it for about 20 miles the first time-no Tire warning message.
Then a few hours later about another 20 miles-still no warning.
Im thinking this is really odd??Then as I pulled in the Driveway,I had some kind of message about the tires-for a while there I thought I was the only guy who had an 06,that would "relearn" its own tpms-LOL.
#36
When the TPMS is not getting data from the sensors (dead battery in a sensor, sensors in tires aren't programmed into the TPMS) you can't put the AH into the Comp mode or turn it off completely. The AH goes into a very intrusive mode to protect you from driving aggressively because it thinks you have a flat tire. The ABS will put on individual brakes when you turn, and the ECM will pull power when you try to accelerate unless you are going perfectly straight - it makes the car undriveable at a track event, although you shouldn't have any problems with easy driving on the street. That's why owners that track the C6 either run sensors in their track wheels, or try some workaround like sensors in a pressurized canister.
Bob
Bob
BTW, your explanation highlights why I don't understand how the canister scenario can ever work. My understanding is that the computer in my 07Z will complain and invoke intrusive AH in 20 minutes after detecting no/incorrect pressure in any sensor (or missing a sensor). You indicated it took more than a bit of shaking to wake a sensor from sleep mode, and when in sleep mode, a sensor transmits once every 60 minutes, not often enough to stop the intrusive AH mode. Therefore, it's more than likely one or more canister sensors will be in sleep mode during the track day which will make Comp or "all nannies off" modes unavailable. Yet there are some folks on the forum who maintain that they successfully use the canister method for tracking their c6z's..........what am I missing?
#37
BTW, your explanation highlights why I don't understand how the canister scenario can ever work.....Yet there are some folks on the forum who maintain that they successfully use the canister method for tracking their c6z's..........what am I missing?
Bob
#40
No - at least not on my 2009. I've tried it before, but just went out and tried it again and it just would not take the same sensor twice. Each sensor's unique ID# is logged into the TPMS memory, and the TPMS can only hold four ID#'s. Apparently the TPMS software is programmed to not allow the same ID# to be logged in twice - it seems like they must be 4 different #'s.
I don't understand it either - but I have never tried it. Maybe aggressive driving throws them around enough to keep them in the drive mode where they will transmit once every minute.
Bob
Bob
