[Z06] Which Jack?
Thanks for that!!
To contribute to the thread I use the thick aluminum pucks and my jack is a cheapy aluminum low profile job from autozone. My car's lowered and the jack can slip right under the pucks with no problem.. it even just barely clears the rear sway with a 2x4 on it to get to the cross member.
I know most use a 4x4. I guess I just had a 2x4 available so that's what I've used, been using it for a while. Once I go to larger sways I'll have to block the tires up to clear anyway so maybe I'll swap to bigger timber. Thanks buddy
OP, if you're still looking for jacks, I'm about to get the $130 low profile steel jack from Harbor freight. It's gotten some good reviews, is quite long for getting under the C6, & the price is decent as I don't plan to use it very often or transport it. It's a 100lb *****, but shipping looks to be only $20 which is surprising.
Viz
You can get this one from HF for $80. With a beam adapter it will reach the preferred front crossmember jack points if the car is up on two 2x boards (2x10, 12, whatever). 80 lbs IIRC. And no, HF will not accept the 20% coupons on floor jacks.
Be sure and check hydraulic fluid before using an HF jack. I have two of these; both were quite low on fluid out of the box. One was missing the fill plug o-ring. Welcome to China . . . . .
The jack has a crossbolt underneath the puck that prevents the crossbeam from being bolted in from underneath.
It seems stable as a lifting device, since everything is centered, but of course jackstands need to be employed before actually getting underneath. I use jackstands underneath pucks on the outer frame rails (leaving the jack and the crossbeam in place for additional stability).
With that particular jack, it just rests on it with the crossbeam pin as something as a locator (pin has to be filed down; with the jack bolt holding the jack puck in place removed).
Thinking I'll mcgyver a solid piece of 1"x2" aluminum bar stock, & glue heavy duty 1/4" rubber pads on the ends, & 1 underneath that centers on the jack's lift pad.
#34
On the opposite side of the spreader bar from the pads, i have a 1/2-13 hex nut attached with a screw, that drops into the hole in the floor jack(after I remove the lifting cup from the jack), so the spreader bar will not slip off the spreader bar.
#35
