[Z06] What do you guys think of this Z06?
My grandfather is looking to get a C6, and he's put me in charge of finding him the best deal/best car for him.
Anyways, I found this Z06 on autotrader;
http://www.autotrader.com/cars-for-s...30743930&Log=0
Asking Price: $40,999
KBB:
Excellent: $47,464
Very Good: $46,564
Good: $45,564
Fair: $42,464
Before we go look at it, what are common things to look for? The ad says that there are a few imperfections (loose shift boot, a few paint chips, and some wear on the carpet in the hatch). I've never sat in a C6 nor do I have any experience with them. The price is really good compared to what I've seen other Z06's go for, so I was wondering what you Z06 guys think about it.
Thanks in advance guys,
-Jay
KBB:
Excellent: $47,464
Very Good: $46,564
Good: $45,564
Fair: $42,464
-Jay
Well, from what I can see, the exhaust is aftermarket and it has headers so it's most likely tuned. Depending on who tuned it and when, there's no telling the condition of the engine. I would have a reputable tuner (one who can inspect the tune) look it over before pulling the trigger on it. If they have documentation and receipts of who did the work and when, all the better. Buying a modded car without knowing who modded it is a gamble, especially in light of what's going on with the valve guide wear.
Bottom line, if it has the modifications you'd otherwise do yourself and you can trace the modifications to someone who knows what they're doing as opposed to some fly-by-night or amateur "do it yourselfer", then go for it. It's a good price for what's on it. If you can't determine who tuned it or if the ECM is locked, then you're taking a chance on potentially someone else's problems. You'll also be looking at putting more money into it to have the heads inspected if it has an aftermarket cam. Who knows, though, perhaps the head work was already done by the previous owner. See if you can get documentation on the modifications.
Side note, the passenger side fuel rail cover is loose, so it may have been messed with recently. Pop the covers and take a look for any signs of "hack" jobs. And get it up on a lift to check the underside wiring. I've seen the work of a choice few shops who'd be better off weaving baskets for a living than trying to work on cars.
Be very careful. That kind of wear indicates high mileage or abuse. Take it to a Corvette specialist and have them look it over. Look at tires (can be $2K per set).
KBB:
Excellent: $47,464
Very Good: $46,564
Good: $45,564
Fair: $42,464
-Jay
KBB:
Excellent: $47,464
Very Good: $46,564
Good: $45,564
Fair: $42,464
-Jay
z51vett
Maybe it isn't tuned. Surprisingly, a lot of people don't tune their cars after CAI, exhaust mods, etc.
He likes all of his cars as close to stock as possible. He doesn't mind good sounding exhausts though. I'm staying hopeful, but I'm not going to be knowingly oblivious to red flags in this car.
Lots of assumptions made here, rough in a few spots (front splitter), but overall seems ok. Brakes are also aftermarket, likely better than the OE pieces.
Being an 07, you may want to see if it is affected by the Rocker Arm issue.
Would look at the Z06 home page and read through the rocker arm needle bearing issue. It's out of warranty as well so you have to be wary of that too. Looks a little rough for only having 40k miles. Not sure what would wear out the rear carpet that quickly either but guess you can see how bad it is. May check inside tire wear and see if it's been lowered. They're relatively solid cars so just listen for any noises. May be hard to do with the aftermarket exhaust though. Good luck.
Location: Murrells Inlet, SC (formally New Windsor, NY)
With the addition of the Stoptech brakes I would think the car was probably tracked. It's an expensive mod to do to a car that just sees street duty. The stock brakes are more than adequate for the street.
Not a bad price if the car checks out, but there's a lot of clean, used, low mileage Z's out there. Me personally? I'd keep looking. $40k is a lot to spend on a car with question marks. Good luck in your search.
If its got CAI and headers, it's a good bet there's a tune also. No sense in running those mods without a tune. The problem you run into when buying a molded Z is you're not always in the know of who installed parts and tune.
Okay just got a response from the owner. The Magnaflow is a cat-back system, headers and cats are original. And the car has NOT been tuned, like I thought.
37k tops. 40k can get you a decent 08z. When I was looking not to long ago I had a few good offers thrown at me just from posting up a WTB Z add. GL
Here is a good tip...run your hand along the rolled edges of the hood. If the paint is rough the car has been repainted. Look at the bolts that hold the fenders in place and look for signs of removal/re-install (i.e. cracked, broken or disturbed paint). Also look for overspray in these areas that would show repaint. I'm saying this because CARFAX is crap and can be gotten around very easily. You want to do a few quick gut checks to see if the car has ever seen any damage.
Also, SRV is my all time favorite guitarist. I spent this past summer learning as much about Stevie as I could. Man that guy could play.
Since you asked. Yellow would not be my first choice. Those great Z06 lines seem to vanish on a yellow car. Also........
Ticket magnet
People looking for a cab will be flagging you down
You might be confused with a construction vehicle.
Just kidding, but I would look for another Z06, good luck!
Ticket magnet
Ticket magnet
Ticket magnet
And we both drive like grandpa's anyway, so the cop magnet part doesn't scare me too much. If it doesn't seem like a good car, then we'll keep looking of course.
Thanks for your opinion!
I wouldn't buy that one, at least go for an 08 with the carbon fiber interior for slightly more.... I wouldn't buy one with a splitter in that bad of condition, dead giveaway the owner is not really taking that great of care of the vehicle. Just my opinion...
