[Z06] New Dyno Numbers WCCH Heads
10-30-2012, 02:32 PM
Mods:
Wcch stage 2 heads
Fast 102
N/W 102
Cam
Kooks W/Cats
B&B Fusions
Halltech 107
I think they turned the smoothing down on the graph.
10-30-2012, 02:35 PM
Cruise-In X Veteran
Quote:
Originally Posted by
millerjj
Mods:
Wcch stage 2 heads
Fast 102
N/W 102
Cam
Kooks W/Cats
B&B Fusions
Halltech 107
Nice
What cam are you running??
Mark
10-30-2012, 02:39 PM
Custom one from Chucks Tunning in Houston. I think I am going to swap it out as its only a .630 lift cam
10-30-2012, 04:53 PM
millerjj
Wow great numbers for that size of cam.
10-30-2012, 05:19 PM
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
It makes great HP, but the TQ seems low. What are the specs on the cam?
10-30-2012, 06:31 PM
Post it again with smoothing on 5 if you can.
10-30-2012, 09:36 PM
that car appears to have either a bent rim or a bad axle... or extremely unbalanced wheels?
10-30-2012, 10:21 PM
spinning the tires on the dyno.
10-31-2012, 08:14 AM
No the tires are good. The smoothing is just to low. The cam is a good cam but I think I am going to try a Ragin Racin or Black Mamba cam
12-06-2012, 09:34 AM
12-06-2012, 09:52 AM
RichieRichZ06
I think with a different cam you should be able to snag a generous amount of tq. Nice power, but there's some on the table, go get it!
12-06-2012, 09:55 AM
go see mike at G force he will do a custom cam for u imade that power with stock heads and TB and intake
12-06-2012, 10:24 AM
12-06-2012, 11:27 AM
You car would have made a lot more power if your heads werent deburred ...
12-06-2012, 11:51 AM
mookster
you car would have made a lot more power if your heads werent deburred ...
hahahaha!!!!
12-06-2012, 12:00 PM
Torque is really low. Maybe it is the "custom" cam.
12-06-2012, 12:02 PM
12-06-2012, 12:16 PM
That's a good looking power curve, I wouldn't worry about peak numbers. It seems that combo is pretty well matched up.
12-06-2012, 02:00 PM
Mookster
Whoa! Good catch Mook! Look into that OP....
JK - great numbers, enjoy it.
12-06-2012, 03:25 PM
It runs good. Its just hard to spend another grand to try another cam. I really want to do a clutch setup next
