[ZR1] 2010 zr1
2010 zr1
Has any one tried to flush the fuel tank from there new zr1 yet. Unable to jump relay because there is no relay. Zr1 has a fuel module to turn on the pump. Next step is to push the shrader valve on fuel rail and let it out like this while car is running,will take a long time like this !!! Car sits for long time, and i want to get the gas out and fill it with fresh gas to store for winter. Any help would be great !!!! Thanks in advance to all..tom..
Zr1 fuel tank drain ???
Has any one tried to flush the fuel tank from there new zr1 yet. Unable to jump relay because there is no relay. Zr1 has a fuel module to turn on the pump. Next step is to push the shrader valve on fuel rail and let it out like this while car is running,will take a long time like this !!! Car sits for long time, and i want to get the gas out and fill it with fresh gas to store for winter. Any help would be great !!!! Thanks in advance to all..tom..[/QUOTE]
I would try to drive the car once or twice a month in the winter when the roads are dry and salt free if possible, and keep the fuel topped off.
yeah, you're way over doing this situation. Just drive it down to a 1/4 tank and top it off with fresh fuel and you'll be fine. Newer fuels last a long time before they break down. If you are totally stressed, drive it a 1/4 tank, then top it off, drive it down to 1/2 tank, top it off, then drive it down to 1/4 tank and then fill it up and you'll be good for the winter.
star bright is great stuff for fuel that's old and not treated. put some in the tank thane let it sit overnight. def will help. works on my bbc camaro everytime i let it sit too long.
I had a big power sand rail that would get stored for long periods of time with old fuel and never had a problem with it. I would hammer it right out of the trailer after a long winter. I have read that modern fuels do not lose octane for a long time. I really think you're over worrying.
I always keep the tank full when i store it. The problem is the car only has 166 miles on it and the weather now in rochester ny sucks..iam kind of strange like this [not driving it] stone chips and crazy people on the road..i know,, why did i buy the car in the first place ??? I have heard that millions of times..thanks for all that have replied.
