[Z06] Hit the track today
Hit the track today
We went to the track today ,temperature was ideal here in montreal nice tail wind wasnt planning on running but the weather was to nice to resist.First time at Napierville dragway this year,on regular street tires though not runflats,dunlop uhf,1.87 sixty foot time 11.74 at 123.89mph,07 z06.Next time out will be on drag radials as i feel these cars are seriously held back by lack of traction.Got my tires waiting to receive my wheels and then we will see what she can do with proper hookup.I seriously dont see how anyone had seen low elevens much less high tens on stock rubber at nearly 130 mph.Ill be running 17x9.5 wheels with Mickey Thompson drag radials next time i go.Was a fun day had a couple of buddies there .
I must add that i have less than ten runs total with this car since i first bought it.I think 11.5 will pretty much be the best it will go without drag radials,that of course with a few more practice runs.Il never get to know for sure because it will be drag radials only when i hit the track from now on.
today i had a cold air and a tune last year i ran 11.77 at the same mph all stock so the tune and cai did nothing to make it any faster.Although on the dyno i did gain 30 h.p and 30 ft/lbs of torque.The car feels excaclty the same as it did all stock.Same mph essectially same time in the quarter.The best thing about the tune was getting rid of the caggs,1st to 1 skip shift ,man that was annoying.
the car is fast so its hard to feel the difference but i m hoping that with drag radials ill see good times.As i said i have less than ten runs total with the car so the times will drop but people hitting 129 and 130 all stock,i dont see that as reality.11.2 on drag radials would be nice but it wont be easy.Got to get the right clutch action going and make sure i get 7000 pms out of first and second gears.I think i m shifting a bit early out of first and second and i am leaving a couple of tenths and mph on the table.We will soon find out.
Those people are also running at tracks known to be fast and have like -2000da so their times/traps are irrelevant to me, most people are only trapping 119-124ish stock it seems typically. But you'll notice when you put the DRs on and more passes, my goal would just be a low to mid 11@125-127 if I were you that'd be plenty respectable IMO
Now it might be easier for you to appreciate some of the driving accomplishments of the more skilled Z06 drivers.
None of us who have hit high traps speeds or low ET's did it on the first 10 passes.
You'll need to get into 4th gear at the 1000' mark to run the upper 120's.....you'll be limited to mid 120's at the limiter in 3rd gear on stock diameter tires.
I ran my 10.92@129 in AZ with a DA well above 1500'.
When a couple of us made the trip out to NorCal to run Sac a year or so ago, most everyone ran about .14-.20 faster in the lower DA.
With practice, you shouldn't have any issues running low-mid 11's in your local.
You are right i am going through the traps at the end of third gear,and, i feel that with 17 inch drag radials ill shift into 4 th gear and raise my mph.This and the fact that i feel i am shifting early out of first and second gear will lower my e.t and raise my mph.Thanks a lot FNBADAZ06 I know i cand rive and seat time is priceless when getting familiar with a manual high powered car.I should be in the 1.6 range sixty foot times on drag radials ,raise my 1-2 and 2-3 shift points ,hit 4th at 1000 feet and break all the records.Oops i m getting ahead of myself .Anyway ill keep you posted with my times and trap speeds on drag radials within 10 days .Thanks again.
Address the driver skill before jumping to tires. All they will do is mask your errors and you still won't be as fast as you can. I personally ran a 11.6 @124 with a 1.8 60' in regular Georgia weather last year in April. This was on NT-05s with an airaid intake, vette air, bassani exhaust and a ****** MTI tune. Also I was at full tire pressure and on zr1 replicas which are heavier than stock
Seat time, seat time, seat time.
You are right i am going through the traps at the ned of third gear,and, i feel that with 17 inch drag radials ill shift into 4 th gear and raise my mph.This and the fact that i feel i am shifting early out of first and second gear will lower my e.t and raise my mph.Thanks a lot FNBADAZ06 I know i cand rive and seat time is priceless when getting familiar with a manual high powered car.I should be in the 1.6 range sixty foot times on drag radials ,raise my 1-2 and 2-3 shift points ,hit 4th at 1000 feet and break all the records.Oops i m getting ahead of myself .Anyway ill keep you posted with my times and trap speeds on drag radials within 10 days .Thanks again.
Whatacop drag radials dont mask your errors they help you get out of the hole.My mistake is shifting out early out of 1st and 2nd.Your times are with more stuff than i have and i ran the same 11.7 100 per cent stock last year.Your mph is no higher than mine so you need to practice you shift points as well .FNBADA gave me the right advice and until another guy much faster than me talks he is the only one s advice i m going to follow.You also had Nittos on which hook up better than my little generals and i still went 1.87.
Also, I'd go ahead and proceed with your plans for the drag radials.
Running the drags on street tires in these cars, I believe is a lot safer with a stickier drag radials than with the street tires.
Indeed, show me a C6 Z06 in here or a C6 ZR1 which has hit the wall at the drags, and 9 out of ten times I'll show you a car which was on it's stock street tires when it did it.
http://forums.corvetteforum.com/c6-z...lked-away.html
http://www.ls1tech.com/forums/easter...riday-ned.html
Street tires are for the street. Track tires are for the track. Get the drag radials, heat them up and enjoy better traction and safety at the drag strip.
Just me, and I am certainly no expert, just me now, and after seeing several 2.x 60ft times on street tires from Nittos NT05s, to Goodyear Eagle F1 Supercar EMTs, but I have gotten to a point to where I believe at the stock C6 Z06's power level, running one of these cars on a drag strip on it's street tires, especially at a typical test and tune with the usual poor track prep associated with such events, is a complete waste of time, and an exposure to unnecessary risk, over and above that already taken, and you are already assuming, when you go to the dragstrip anyway because of the poor traction your street tires are going to offer you there.
Think about it. Callaway makes no attempt post up their Supercharged grand sports quarter mile times at drag strips on street tires. They use, and tell you in their promotional literature and advertising that they are using, drag radials on it, when they go to establish it's quarter mile results for their advertising purposes.
They don't even waste time on street tires.
I feel this way about doing so at test and tunes where track prep is typically poor to non existent and on crowded tracks, cars spilling their guts on the track and making a crowded day even more crowded and backed up due to cleanup, and thus lean more towards running rentals when or if I can, or I don't track the car at all.
Finally, if you notice, most of those fast times you referred to in your earlier post, were during rentals, where only a few cars were running, driving could be dialed in through multiple passes, tire pressures and launch RPMs dialed in... Hard to do in only 2 or 3 passes during a typical test and tune. Add onto that track prep was out to whatever distance the guys renting the track wanted to pay for and the picture becomes clearer.
Good luck though. And get those drag radials.
You are right in that short shifting will indeed kill your times.
So you're saying that with DRs you shouldn't have this problem?
I was just about to start a new thread asking about all these videos (only a few actually) I see with Z06's crashing at the strip. The video I saw was of a Z06 getting out of control from the 3rd to 4th shift - I think - and of course with TC OFF.
What I'm saying is most street tires offer less grip than drag radials.
Just me, but if I'm going down a drag strip at WOT, in a car as powerful as a C6 Z06, then I want a tire on the rear of it which will give me better traction and grip than I'll get with it's stock runflat.
On top of that, the drag radial also gives me my best chance at a good quarter mile result. Spinning on my street tires is just wasting gas, wasting the track fee, and running risk I no longer want to add onto the risk I'm already taking.
You don't want to be spinning and sliding due to lack of traction, with your foot all the way into the throttle and that wall just a few feet away, and that is more likely to happen on a street tire than on a well heated drag radial running the right tire pressure.
But all of that said, drag radials are no guarantee to keep you out of the wall if the car gets loose on you.
No, definitely not saying that.
As per running with TC on, I don't think you can even do a burnout with TC on.
If you refer to Ranger's write up, he recommends making quarter mile passes with TC off, and explains why.
http://forums.corvetteforum.com/c6-z...post1577460243
I've made quarter mile passes in my car on street tires, but I'm through doing that.
