[Z06] Traction Control Off/Competitive Mode
Can someone please explain the difference between the two, and more importantly is there any performance advantage in being in one than the other?
Hit the botton once....you have control of the rear wheels and the computer does everything it can to keep you between the ditches. I would use this if you drag race.
Hit it twice (comp mode)....you have control of the rear wheels and the computer does NOT do as much to control the car. This is what you would use if you road raced or autocrossed.
Larry
Larry
Larry
Larry
Larry
Larry
Basically the traction control off (one push on the C6 Z06) allows the rear tires to spin with you in control via the throttle, however the stability control system will intervene just like normal.
Two pushes and you are in Competitive mode, with traction control off and the stability control system in a relaxed mode of intervention i.e. it will let the car move around a lot more before it intervenes. For a novice road racer or for a drag racer, the normal stability control system should be OK.
For an experienced road racer, I find the Competitive mode is fine as I react to what the car is doing well before the relaxed nannies intervene. Some experienced road racers have said that when the nannies intervene they have had big problems because there response to what was going on conflicted with what the nannies wanted to do. For those that are concerned about this they push and hold the button down 5 seconds and shut all the nannies off (normal ABS still works). The all off mode can also be used if you want to do donuts or burnouts (I don't).
Larry
Larry
However, the TC/AH is fairly aggressive in "all on" mode so it can catch wheel spin/sliding that the driver can't feel/hear. This may give the illusion that it is just blindly stepping in.
From what I have read and experienced, the computer only intervenes if you are spinning the tires or sliding - intervention could include reduced timing, lower throttle and brake application. Otherwise, it just sits back and watches.
it does modulate the throttle to keep car in control. there is a whole lot going on when this system is in action. depending on what level its engaged determins how evasive it is.
This usually only matters on exit, and too much pedal breaks the rear tires loose, the car slides, nannies kick in, and it doesn't matter how much you mash the gas, the car goes nowhere, as the input from the gas pedal does nothing. My experience is that this lasts for at least a second, or until the rear end hooks up. It kills your time, whether on the track or autocrossing.
If you're driving for time, push the button twice, and let the chips fall where they may
Yes, hold it down for about 5 seconds on the C6. The other modes are different as I think one push on the C5Z puts it in Comp mode and on the C6Z it's 2 pushes (one for traction off only).
When I roadrace ours, I have to turn everything off. At the ragged edge, with either TC on or Comp mode on, it keeps applying the brakes and just cooking them. My best times and least drama occur with everything off. I'm running Hoosiers and Stoptech brakes with coilovers. Maybe I'm outside of the computer parameters.
For me it's worth 2 full seconds on x cross to turn it all off.
It's probably the safest way to see if you need it.
Tight twisties on a canyon will have the back brakes on ALLOT.
Something about having the rear brakes applied, (by someone else) while I'm on the throttle, doesn't sit well with me.
If you crash, you say I was driving but that culprit applying the brakes at inopportune times will be taking NO responsibility.
