[Z06] Warrantied Engine Replacement Question
Has anyone that had their STOCK engine replaced under warranty ever had any problems with having warranty cover the replacement? I just read the thread about the guy who'd bought a used Z06 and had to have the engine replaced and when the engine computer was read by the GM engineers, it found that the car had been tuned at some point. I'm not too worried because my car was GM certified pre-owned when I purchased it and it's never been modded or tuned. I just don't want any surprises. Your thoughts...?
Also make sure they refill your transmission fluid after they replace the radiator. Don't ask me how I know that they didn't on my car.
I had mine modded and it was replaced under warranty. A stock engine with no mods to anything would most certainly be replaced under warranty. Also if its still under GM warranty and not a 3rd party it has to be a brand new crate motor.
I had a cam, intake, exhaust, and tune. It took them about 2 weeks before it was all said and done. The new engine actually felt better than the old engine, but I only kept the car for about a month before trading it in for a ZR1.
Wil Cooksey #256
I had a few mods on mine: tune, CAI, LT's. Oil was getting into the coolant and it was thought it was doing that since the car was new. All hoses were coated in oil and had two water pumps leak because the oil in the coolant would swell the O-ring and it would leak. I had to follow GM's process to insure it wasn't anything else. After everything was exhausted GM decided to swap out the engine. Had no problems.
That's good to hear. Too bad the ZR1 is too expensive. Hell, mine is too expensive. LOL
I didn't feel like dumping all the money required into the LS7 to make it reliable. Nor deal with aero, suspension, or brake upgrades. Even though its a big difference in prices I will get a return on the ZR1 when I sell it. With mods on a Z06 I will get 10 cents on the dollar when I sell it with mods.
I can see that. I hate that my confidence in the LS7 is shaken, but truth be told, it is. I'll give the new engine a good long shot, but I'll monitor it very closely.
if gm wants to see calibration numbers listed from your car, the dealer takes a photo of the tech 2 screen that has those numbers and your vin# and sends it to the tech/warranty dept. if its stock and never been messed with then your ok. and yes they will know even though you might have reflashed back to stock.
be careful I bought a certified GM car and it turned out it was tuned. I took it to the dealership to flash the original tune back in and they couldnt do it because who ever tuned the car had a locked tune in it (but they told me they did!!)
I didnt use the warranty but I am just telling you to go check the tune on your car.. I am afraid if it fails at some point and they pull the tune of your car and notice it was tuned they will say that you did it..... again this didnt happen to me but my car was tuned when I bought it from the dealership and they had no idea!!!
Well, I sure hope no surprises come up because I was assured when I bought the car that it was indeed stock and hadn't been modded or tuned and I've done nothing to it except take exceptional care of it. I pray to God that they warranty my car or I don't know what I'll do. Thanks for the input guys.
The computer records the date it was flashed. If you go to have your car worked on and it was flashed before your purchase date and then was validated by the dealer as being certified when you bought it then I am sure it wouldn't be hard to get them to cover the car under warranty. May take a lawyer and some nasty phone calls or letters but you can get it done.
