[Z06] Warrantied Engine Replacement Question
The computer records the date it was flashed. If you go to have your car worked on and it was flashed before your purchase date and then was validated by the dealer as being certified when you bought it then I am sure it wouldn't be hard to get them to cover the car under warranty. May take a lawyer and some nasty phone calls or letters but you can get it done.
Troubling issue. How in Hell would a person buying a used Corvette possibly know that the car had been 'tuned' in the past?
If it is determined that the car had been tuned, should it be avoided, just on that basis? Perhaps there is far more involved in 'tuning' than I realize, but why would tuning void a warranty?
I definitely agree with you. It's one of those things where you just have to hope that the powers that be side in favor of the guy that bought a previously tuned car unknowingly, especially if they've left it stock.
Troubling issue. How in Hell would a person buying a used Corvette possibly know that the car had been 'tuned' in the past? If it is determined that the car had been tuned, should it be avoided, just on that basis? Perhaps there is far more involved in 'tuning' than I realize, but why would tuning void a warranty?
when you tune your ca you increase the power and also some tuners take it over the "safe" limit. Tuning might cause engine failure (running lean) usually the factory have the car a little rich and lower the timing a little too to make sure the car last longer and the chance it will fail is less. yes you lose some power by doing that, but for them they would rather that since they are giving you 100k miles warranty on it!
Yes, I am just waiting for the GM engineers to give the go ahead on the warranty claim. That's how I understand it from the rep at the dealer. Hope I hear something today.
Received 8,975 Likes
Bill
The dealer called and they said that GM was able to see that it had been custom tuned at some point. GM says that if the engine tear down reveals a cracked piston, they will not honor the warranty. So now I have to wait to see what the engine year down reveals. I'm not happy about this.
Let me clarify and say you aren't going to be chasing down GM with your lawyer, but the dealer that did the certification.
x2 unfortunately....Dealer will be out the money, not GM though.
#33
I asked that and apparently there wasn't a stock tune in it so they don't have a date. He said they can't get a date at this point.
#34
#36
#38
I went to the dealership and told them that I keep getting a CEL (lien or rich cant remember) and they found out later that the car was tuned and they told me "they put it back to stock!" I checked the next day and they LIED coz the tune was locked in the car and they couldnt flash the stock tune back. I knew that because I tried to tune the car again and it still had the previous locked tune in it. Paid $250 for nothing
I really hope this will work out for you. I know that they can find out if the car was tuned at some point previously but I had no idea that you can see the actual date. that will help you in your case. GL and keep us updated
#39
We can't blame GM for possibly denying the warranty since the engine was tuned
If one of GM's authorized dealers certified this car with a tuned motor in it then I feel they are partially responsible. Hopefully GM will put pressure on that dealership and get you taken care of properly.
Best of luck. And I am going to predict a good outcome for you
Go GM !!!
DH
Go GM !!!
DH
#40
Something I remembered: a year ago I had the skip shift tuned out and the fans made so they run a little longer after the car shuts off. Could that nullify a warranty? Otherwise my car has never had the computer altered in any way. Does that count as a "tune"???
