[ZR1] What did they do to the base 6.2 liter engine to turn it into 680 HP Monster?
I know about the supercharger. What I am looking for is what are the structural changes GM made to the standard 6.2 liter, other then the supercharger to make it this beast? I'm talkin all the modifications GM had to do to make the ZR1 engine stay together for the long term.
_"SCOTT"_
_"SCOTT"_
I believe the LS9 also has a unique block casting (material and method)...also has larger head bolts and a more robust head gasket design. Head casting material, valves, More flywheel to crank bolts, oil pump may be higher capacity due to the piston spray jets, etc. Likely other changes beyond what was mentioned above.
Here is the "big picture"
Block is the same casting its just machined differently.. Difference include the squirters, head bolt threads of course, and also the depth of the crank sensor (to help rigidity).. The heads are cast a different way to make them stronger and ports smoother. Roto cast is the name for the process.
The block #'s are the same so I doubt any difference. The head #'s are different so we know they are not the same. Anyone have a source that goes into detail on the internals of both engines???
Well i know the webbing is different on the ls9.Also the head studs are 12mm.The LS9 has billet mains and oils squirters.I just called SDPC and the guy said they aren't the same casting.The have different part #'s.
They are not the same. Here are the casting #'s for the c6 blocks.
12564243
LS2 (6.0L/364ci)
2005-2007
12600821
LS3 (6.2L/376ci)
2008-Present
12578452
LS7 (7.0L/427ci)
2006-Present
12621771
LS9 (6.2L/376ci)
2009-Present
12564243
LS2 (6.0L/364ci)
2005-2007
12600821
LS3 (6.2L/376ci)
2008-Present
12578452
LS7 (7.0L/427ci)
2006-Present
12621771
LS9 (6.2L/376ci)
2009-Present
Per the Corvette Black Book written by Mike Antonick -
2009 thur 2012- Block#: 12621766 376ci, 430hp and 638hp
LS9 Document
I have a .pdf document from GM titled "2010 LS9 Description" that describes the distinctions. IF someone can tell me how to post this document, I will.....or it is likely avail via a web link that I can't locate at this time?
Also, see a neat animation at http://www.youtube.com/watch?v=mIKNccRDvRo
Dick
Dick
The blocks are the same but will carry dif part #'s because of the machining. If the ls9 has special machining but they could be the same they just block of piston squirters. Bare blocks now not short blocks. When the ls3 came out they talked about the dif between it and the ls2 engines and how it was beefed up. This makes me think they are same but machined diff.
z51vett
z51vett
z51vett
