[Z06] Mod suggestions for my Z06
I just purchased an 08 Z06 that has 14k miles and is bone stock except for the mild to wild switch. I have never had a Z06 before nor even a corvette and I have noticed how expensive exhaust is for the car. Im not interested in doing heads or a cam in the car. I would like feedback on which exhaust components/cold air intakes did you guys see the most rear wheel horsepower gains from. I'm just trying to justify dollar to seat of the pants ratio. I was thinking longtubes and a highflow x pipe and maybe keeping the factory catback, but if theres not enough power gains for the money I wont do it. What do you guys think? Also Im buying tires this week. The factory ones suck imo so im looking at the new Michelin Pilots sports. Im looking for traction cause it has none right now. Thanks alot guys for your input.
As far as CAI's are concerned the most air being drawn into the intake will be a from callaway system. Should be around $500.00 give or take.
As for tires I'd go Nitto NT05 Street tires 285/35/18 Up front and 345/30/19 Nitto NT05R Drag Radials out back They hook very well and drive just fine, or if you want a street tire with less traction go with the Nitto NT05 Street tire 335/30/19 on the rears
I have no codes from my 285/345 setup
and yes you do need the X-pipe, I'd get it with High Flow cats because IMO the car sounds better with them and smells better
I bought the same thing only 2 years ago. A 2008 with 14k 2lz with only a mild to wild. I had plans since I removed all my mods from a 2008
base car that i bought new and sold.
I would save your money and simply do a Supercharger kit.
That way you get the big power and can remove it. Just save all your stuff you remove. I drove mine till it hit 20k and added the kit.
I have an A&A kit with a sl1500 paxton head unit.
It takes the car to a whole new level. I turned 600 rwhp and 580 rwtq
at less than 6000 RPM. The engine was fully heat soaked (timing pulled)at 230 degrees (long story) but everything is right with 12 degrees of timing. So It should be doing 650/620 or more when cool.
I find it is less hard on the car because your using less RPM's
because of power surplus.
It's really the best mod to do!
Your local GM "stealer-ship" is just trying to steer you away from another brand of tires that they either don't sell, or don't make enough $$ off of.
Go with the Nitto NT05's, you wont regret it <- and your car won't throw any codes - ask me how I know
I did post on svtp. I came out of a cobra. Man what difference!! Please send the clip. What catback is it? I've been looking just have no idea what to do. I like a higher pitch sound. Which company offers that?
All the exhaust stuff is fine, but you mention cost to hp, and it's high. Best bang for the buck....is a simple street tune.
Larry
Larry
If you want all out traction and to dead hook 1st gear than yes I would get them, it won't be as good in the corners of course but still handles fine and is very stable up top in the NT05R's (Drag Radials). I daily drive my Z06 on them have been in the rain/wet roads with them a couple times with no issues. It's the only tire I'll ever put on my Z06 again but I only care about straight line and don't want to bother with peddling it I want to dead hook when I do pulls
Corsa IMO is the best sounding catback with no drone but you definitely pay for that tho lol $1500
http://www.youtube.com/watch?v=MsHYEAIMlos
As said earlier...I wouldnt even mod the car until you decide to tune it. Sooo find.a.good.tuner then do CAI (Halltech), headers back exhaust, and.a.tune. Like most everyone else your car should respond well (depending on your tuner).and make good usable power.
And of course a nice.set of sticky tires out back will help put the power down.
Former Vendor
Stick to poker lol.
If you were only going to add one to an intake/tune Z which would it be a Ported Stock Intake/TB, Headers, or Fast 102?
