C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] My LS7 is on the way to heaven.
Old 02-04-2012, 09:06 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Default My LS7 is on the way to heaven.
Well my build didn't last long. Was driving up to cars and coffee here. Was going 75mph on the highway when I noticed the knock sensor started going off. I turned the radio off and didn't hear anything but to the next exit. Made it into a parking lot and there was a light knocking noise. I popped the hood and couldn't see anything wrong but didn't want to try to start it so I towed it home.
Was thinking I broke a valve spring or something. I took the valve covers off and the plugs out. The front passenger plug was black which was the only strange thing. All the springs, rockers, pushrods, etc all looked good. I couldn't figure it out. I then pulled the valley plate and that is when I found the damage. The front cam lob was wiped out and the roller of the lifter was gone.
The roller tip of the lifter is snapped off. Not sure what the plan is besides continue to tear it down. Very least it will need to get a new cam, new lifters, etc but if I'm going that far I may just pull the motor and build it or buy a new motor and swap it in.
Ohh well, ran really good for 750 miles. Looking for suggestions on what to do.
Old 02-04-2012, 09:11 PM
3LZZ06
_"SCOTT"_
Support Corvetteforum!
3LZZ06's Avatar
Man...that just sucks!!!
I know you had a blower but what was your the rest of your build list?...
Sorry to hear of your mess.
Old 02-04-2012, 09:13 PM
LS9Drew
LS9Drew's Avatar
Forge the bottom end ,lower the cr, and add more boost lol
Old 02-04-2012, 09:19 PM
Unreal
Unreal's Avatar
Stock bottom end. Comp 228/234 630/630 115lsa cam. Texas Speed PRC 285CC heads. A&A kit.
Need to see what can be saved and what is trashed. Now I can at least get a better cam in there. Not sure if I'll use this block or do a sleeved ls2/3. It really depends on what my options are. No way a stock motor is going back in if I have to pull the motor.
Old 02-04-2012, 09:20 PM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Sorry to hear that your boosted LS7 motor bit the dust, that really sucks and hope your up and running soone than later.
How many boosted miles did you have on the engine and what was the total mileage on the it?
Best of luck to you.
Old 02-04-2012, 09:22 PM
Unreal
Unreal's Avatar
32k miles, 700 since the heads/cam/blower. Wasn't even on it or boosting at all. Just cruising with the cruise control on at 75mph. I have the datalog recorded. You can see where it let go. Now I need to figure out what needs to be replaced.
Cheapest case:
New cam, New lifters, 2 new head gaskets. I'm worried junk in the pan though. I guess I'll see what the oil pump looks like when I pull it.
Worst case the lifter bore is trashed which means the block is trashed and I start new.
Old 02-04-2012, 10:15 PM
Hirohawa
Hirohawa's Avatar
Sorry for your troubles. I know you spent along time getting it all together.
Hope you have better news ahead as you continue to tear it down.
Old 02-04-2012, 10:33 PM
Unreal
Unreal's Avatar
Either way atleast one head/blower/cam/oil pan all have to come off to get this fixed. At that point I might as well just pull everything out. Ugh. Wondering how hard it is to pull the motor out the front/top.
Old 02-04-2012, 10:44 PM
johnnywoz
johnnywoz's Avatar
Bummer, I can relate. Lost my motor a couple weeks ago due to an oiling issue.
Old 02-04-2012, 11:09 PM
RedZ4me
RedZ4me's Avatar
curious, did you have adj. rockers and possible that they weren't properly set.....?? tough to wipe a lobe and incorrect adjustment is often the cause.
Old 02-04-2012, 11:19 PM
tjwong
tjwong's Avatar
You can sleeve the lifter bore to repair it, if the block is otherwise usable, that is a cheap repair compared to a new block.
Old 02-04-2012, 11:22 PM
rattt g
rattt g's Avatar
wow sorry to hear. what going on with all these motors
Old 02-04-2012, 11:32 PM
screaminchevy
screaminchevy's Avatar
Ah that sucks, just saw this. Sorry bro, I'm sure you'll have it up and running even stronger soon enough.
Old 02-04-2012, 11:43 PM
LFZ
LFZ's Avatar
Take it to the dealer....see if you can get that covered under warranty..
Old 02-05-2012, 12:49 AM
OnPoint
The Consigliere
OnPoint's Avatar
Received 5,458 Likes on 2,274 Posts
Sorry to see this.
Hope you get back up and running soon.
Old 02-05-2012, 01:03 AM
MarkRx
MarkRx's Avatar
Old 02-05-2012, 01:11 AM
erikszr1
erikszr1's Avatar
that would be great
To My LS7 is on the way to heaven.
Old 02-05-2012, 01:43 AM
sublime1996525
sublime1996525's Avatar
Damn Nick sorry to hear that. Hopefully it's not too bad and it probably would be too bad to pull the motor out the top. I figure if I could get the motor from the top on a 95 Z28 with the transmission still attached you should be able to do it on your Z. Good luck.
Old 02-05-2012, 08:53 AM
LFZ
LFZ's Avatar
Originally Posted by MarkRx
If other popped modded - LS7s are getting replaced under warranty...so should his.
Old 02-05-2012, 09:24 AM
StreetRacingGuy
StreetRacingGuy's Avatar
Wouldnt it be nice if GM overbuilt their cars like Ford does the supercharged 5.4 and now 5.8 motors?
Quick Reply: [Z06] My LS7 is on the way to heaven.
